As Nino is now racing a 120mm travel bike, you’d think that Scott would have a lightweight version for sale soon. Has anybody heard anything?
I’m on my fifth Spark. I also used to stay in the middle setting most of the time until a helpful shop owner/mechanic gave me some simple advice on my 2018 SL. He said if I’m always using the middle setting I am missing out on the benefits of the full travel and should add air to make the full setting stiffer. Ever since then I set up my shock for 20% sag and run full travel probably 90% of the time. I use lockout pretty much only on pavement and use traction setting mostly for long climbs or gravel roads. The Twinloc is a great feature, try what I suggested and see if you use it more.Are you guys using your Twinlok levers much? On my 2018 I find I leave in on traction mode (middle setting) nearly all of the time.
I am from Houston, retired and moved to NWA last year so I am very familiar with Houston trails. It was the owner of Planetary that got me using my full travel more two Sparks ago! Definitely different up here, today I did an 8 mile ride with over 900’ of climbing, the Twinloc got quite a workout.I am in Houston and we mostly have XC stuff to ride day to day. I do leave it open when things get rooty or rocky, we just don’t have much of it around here. When I got to Austin, it is in open mode a lot more. Just interested to hear how others use it. I saw some stat about Nino Schurter changing it 150+ times a race run (something like that) and it kind of blew my mind.
don’t know if use it so much but for sure I use it a lot, I‘m building a habit like changing gears or pushing dropper lever.I am in Houston and we mostly have XC stuff to ride day to day. I do leave it open when things get rooty or rocky, we just don’t have much of it around here. When I got to Austin, it is in open mode a lot more. Just interested to hear how others use it. I saw some stat about Nino Schurter changing it 150+ times a race run (something like that) and it kind of blew my mind.
I just want to know where you get a lockout for a Pike!Did you build yourself or upgraded with new fork and bars? What is the fork travel?
Where I'm at in Colorado, I've found the Twinloc to be very useful. If you want to go down here, you gotta go up.Are you guys using your Twinlok levers much? On my 2018 I find I leave in on traction mode (middle setting) nearly all of the time.
The bars, wheels, and some of the fancy drivetrain bits I put on, but the pike comes stock on the 940, which is the literal only medium spark my local is going to see this year. 130mm front, 120 rear, as spec’d.Did you build yourself or upgraded with new fork and bars? What is the fork travel?
I have tested Scott Spark 910 and would go for Medium. Same as you I am 179 cm, inseam 82 cm and I prefer smaller frames too, but Spark in Medium seemed to be perfect.I've been looking at getting the Spark RC Team, but the only stock where I live is in size L (with M some months away).
I'm ~179cm and usually opt for smaller bikes, I ride 54cm road bikes and used to have M Specialized Epic HT.
The Scott sizing calculator puts me smack dab in the middle of M and L, anyone with experience of choosing between the two sizes? I'd really like to get my hands on one of these bikes but obviously the right sizing is extremely important
I just broke down and paid $400 for the fraser ic sl dc or whatever. Looks pretty fancy in person.I have a Spark 910 (2022) that I am very happy with. But that handlebar and stem is a boat anchor. Replacing the handlebar is easy and done, but I was surprised that the stem is 180g.
The integrated cockpit makes replacing the stem difficult if you want to keep the clean view. Any suggestions?
It seems to me the only options are to ditch the headset & stem-cover or buy an Syncros Fraser.
I did som "research", and I think the options areI have a Spark 910 (2022) that I am very happy with. But that handlebar and stem is a boat anchor. Replacing the handlebar is easy and done, but I was surprised that the stem is 180g.
Yes. With the Race Face Next R cranks, for example, you can change to the cinch RF136 with the 136.5 mm axle width. I forget how many spacers on the drive side (maybe 2-4 mm ?) and the preload ring on the non-drive side.Is it possible to use shorter q factor cranks on this bike?
I've been thinking about this and eventually figured out what I did wrong. I made two mistakes, the usual one, not reading the manual, and using the supplied spacers with the BB, which are 2.5mm*3 + 0.5mm*1 in size/thickness...Hi guys,
New Scott Spark RC user here, with another question regarding cranksets, q-factor and spacers using Shimano crankset. Yes, I already saw post #195 on this discussion, but the lastest posts were about this too so I'm joining the discussion...
For context, I was using a regular M7100 crankset with a powermeter spider on my former MTB and when buying the new Spark RC I saw on the spec sheet it uses 55mm chainline. The obvious move for me, as I want to keep using the PM spider, was to go for the M7120 version of the crankset, which comes with the stated 55mm chainline.
For reference, I'm using a PF BB86 Token Ninja TF24, thread-in type specific for Shimano 24mm spindles and compatible with the BB92 on the Spark RC frame.
Upon installing the M7120 crank on the bike, the chainline seems good (apart from the chainring teeth going a bit too close to the chainstay protector for my liking, it clears but with no real world use yet), so all good on the drive side. The problem for me is on the non-drive side, as the M7120 spindle is longer (6mm) than the M7100, I had to use 5mm of spacers to be able to install left crank arm and pre-load it/have no gap (I guess it should've been 6mm of spacers but 5mm did it). After installing it like that, the crankset doesn't seem to be centered/aligned with the center of the bike. Looking at the gap between crankarm and chainstay on both sides (by look only and assuming both chainstays have the same shape/are centered, as it also looks like), it seems the non-driveside crankarm has a lot more gap than the driveside arm (I still have to measure this to know exactly by how much)!
Has still have the M7100 regular crank with the 52mm chainline (and shorter spindle), I installed it too just to see what happens, and as expected the chainring contacts the chaintay protector and doesn't spin (obviously).
Thinking about this, I guess I could try to center the M7120 crankset taking a spacer from the non-driveside and put it on the driveside between the crank and the BB bearing, but that would mess the chainline, going from 55mm to 57mm, if a 2mm spacer was used for this!
So, any thoughts, comments, help on this?
