The redesigned Transition Sentinel is now live!
Transition Sentinel 2020 Highlights
How does it ride?
"I've cleaned more techy climbing sections, felt more confident on blind trails, and had more fun riding the Sentinel than many previous bikes. The Sentinel's climbing characteristics may require a bit of readjustment if you're not accustomed to Transition's geometry, but once you find the sweet spot, this bike will most certainly leave you satiated as you clean more technical bits than you have on any other bike."
Read our first impressions here: https://reviews.mtbr.com/review-2020-transition-sentinel
- Full EPS molded carbon frame (front triangle, rear triangle, and rocker)
- New, progressive suspension design
- 148mm Boost dropout spacing
- Stock rear travel 150mm with 62.5mm stroke shock
- Downsize to 140mm rear travel with 57.5mm stroke shock
- Enduro Max sealed bearings with bearing shields on main pivot
- 44mm/56mm Press In Headset
- Threaded bottom bracket
- Molded rubber chainstay, seatstay & downtube protection
- External rear brake cable routing
- Water bottle storage inside the front triangle
- Accessory mount on underside of toptube
- 29-inch wheels with tire clearance up to 2.6-inches wide
- Weight: 7.05 lbs frame with shock
How does it ride?
