Anybody else with a Epic 8 feel a little crammed in the cockpit
I’ve measured the toptube horizontal length and on a size small frame in the high setting it’s 558 not the 568 that specialized states in their owners manual
So I was wondering where the difference lies I checked the reach measured from the center of the bottom bracket to the center of the head tube at stack height and it comes out to 424 mm which aligns with Specialized owners manual
So I then checked the seat tube angle and from the center of the bottom bracket to stack height on the seat post the effective seat to angle is 77° way steeper then what Specialized claims in their owners manual at stack height the seat post measures 134mm which gives me a top two length of 558 mm adding the reach number and saddle setback number from center of the bottom bracket together
This is epic8 expert size small
I went by a couple specialized dealers and measured a medium size and a large size and on both of those bikes. The reach numbers are correct as Specialized has stated but once again same as the small the seat to angle is steeper than Specialized claims both the medium and the large have the same seat post setback at stack height from center of bottom bracket 134mm
Then went to another shop that had an S-works size small in stock and it has the same issue as the expert model in size small does I was hoping maybe because the carbon lab was different that there was a different mold and that was the discrepancy was between the molds and that wasn’t disclosed in the owners manual, but that’s not the case
I’m coming off 2018. Epic works with the saddle set at the same position on the rails.and a saddle height of 700mm from center of the bottom bracket My saddle is 35 mm further forward!!!!
As someone who has worked in the bike fitting industry 35mm further forward saddle change is huge so I slam my saddle all the way back on the rails and now I’m 15mm further forward than my old position but unfortunately after trying lots of things to resolve the issue, I’m not able to adapt to the new geometry I have way to much pressure on my hands and on extended periods of flat trails, I get wrist, pain, and numb hands not good
And had to go to a really upright position to make it work but as someone who races XC at a high level being so upright doesn’t allow me to put the power down and my lap time on this bike has suffered
Please check for your self and measure the top tube horizontal length and effective seat tube angle I’d like to know what other people are finding.
