Chain guides or not
1 reading
21K views 27 replies 23 participants last post by  jorge.alfaro.velasco
#1 ·
I just finished converting my bike from a 2x11 to a 1x12. Everything runs smoothly, chain stays put, back pedaling in any gear. For now, I have put a bash guard with upper and lower chain guides on. My concern is not with the chain just popping off, but wanting to minimize an abnormal ( if anything can really be called abnormal while riding ) circumstance from causing the chain to come off. I'm thinking bad hits, brush, sticks....
What are some of your experiences?
Joel
#3 ·
3000+ miles of singletrack and never had a chain come off...lots of debris around here too. Bike came with GX Eagle 12spd and an x-sync chainring. I put an MPR bash guard on it to protect chain/chain ring from all the rock piles and obstacles we deal with but no guide needed.
I recently converted to 11spd with Shimano der/shifter but stayed with 11spd GX cassette and a new x-sync chainring. Same result...no chain drops EVER. Tooth profile is a little different on the x-sync chainrings (looks like a shark tooth vs traditional tooth design). Combine that with narrow/wide design they hold chains great.
#4 ·
Similar experience here with 6000+ miles on 1x systems with n/w chainrings. No guides, just a bash guard to protect the chain & ring. Personally I've found no reason to clutter my bikes unnecessarily with guides.
=sParty
#5 ·
Good feedback so far. Right now guides are mounted. I guess I'll have to wait till riding season again and just put it to the test.
My hesitation with running without is I have had some unpleasant chain mishaps with my 2x11. The ones I recall were me screwing up ( falling off or nearly so ) and back peddling while the chain is hung up on something. I don't recall ever having a chain problem just riding.
Joel
#7 ·
It depends on the bike and the terrain you'll be riding. My hardtail runs a front derailleur and no chain guide, yet rarely drops the chain. Very rarely.
I tried omitting the chainguide on my full suspension bike (1 x 10 with a narrow-wide chainring) and it dropped the chain at least 5 times on the first ride, on only mildly technical terrain. Needless to say, the guide went back on immediately.
#8 ·
Ive got an MRP top guide and a taco on the bottom. They are so much less complex than in the "old" days. Next to nothing as far as weight. Sure seems like cheap insurance, although I never dropped one on my 1 x 11 on the previous bike without. I'd definitely run a bash guard/taco on the bottom though.
#10 ·
My Calling came with one, never a issue. Always seemed like a good idea My hard tail and my other fully I occasionally dropped. PIA . Chain guides are cheap and easy to install, so I put one on both, haven’t drooped my chain yet
I’ve got bash guards on all three.
#11 ·
Without one, the only chain I've dropped in recent times was during an enduro race when I forgot to turn the clutch back on after installing the wheel. Several thousand vertical foot descents of gnar DH and it never comes off. Even back in the day, chainguides would occasionally jam, so they weren't 100% perfect, but now not even needed.
#12 ·
Kind of humorous to read replies in this thread that say, essentially, "My bike has a chainguide and I've never dropped my chain so why not have one?"
Meanwhile others say, essentially, "I run a narrow/wide chainring and clutch derailleur and have never dropped my chain so why add a chainguide?"
Chainguides are one form of chain retention device. So are narrow/wide chainrings. So are clutch derailleurs. So is proper setup, as in chain length & B-tension adjustment.
How many chain retention devices do we want? How many do we need? IME a n/w chainring with a clutch der and proper setup get the job done. More is belt + suspenders. But that's me. Not saying others are doing it wrong... just wondering.
We each create the machine of our choice. If belt & suspenders is your style, add the chainguide. But I would ask: why not try without first? The chainguide may prove superfluous.
=sParty
#15 ·
yeah, it really comes down to just how rowdy you're getting on the bike. I originally didn't run a guide when I switched to a 1x system but there are a couple of trails here that are fast and rough enough to throw a chain. Of course, that requires that someone is willing to keep their fingers off the brakes. . . . at slower speeds it's not an issue.
#14 ·
I still drop a chain 3-5 times a season or so. I think how hard you ride, how close your chain stay/chain play together, front ring size, and how chundery your terrain is all factor in.
On my current bike dropping a chain harms nothing. If I had less clearance and/or my chain got jammed or sucked in I'd %100 run a top guide. I'm of the opinion the simplest way is always the best way and have little reason to run one currently. I've had chain guides come loose, bend, twist, rip off, get jammed with trail debris, rub, etc., so they're not fail proof.
Sent from my moto g(6) forge using Tapatalk
#25 ·
Sticks caught between the ring teeth and the guide is one thing that can twist or mangle a guide. I've discovered that it depends on the stick and the guide. The style that clamps around the BB can spin if the stick is big enough. That causes some, usually cosmetic damage. It typically requires a trail side "readjustment". Hefty guides may hold up to bigger sticks, but may still get tweaked enough to require a stop.
Lately on carbon frame I have just been adding a strip of protective tape to the BB where the chain would land unless the bike already has a guide. I personally think that the right mix of parts, proper setup, and maintenance has a lot more to do with proper chain retention than a guide. Riding with kids I probably saw 200 chain drops in 2019 with many repeats on the same bike. I can't think of even one case where I couldn't spot the root cause in a 30 second inspection. Clutch off, bad chain line, severely worn parts, bent ring, mix of "speeds", missing teeth on ring ... you name it.
#21 ·
The bash guard I put on had top and bottom guides on. Everything works well so I'm inclined to leave them on, the top is non contact and the lower is on a roller and seems pretty drag free. As I mentioned earlier, I have dropped chains before, various circumstances. The issues I have had have been something forcing the chain off, not just popping form slapping around ( though that has happened before too ). If the guides keep the chain from coming off in those cases, it's worth it to me.
Thanks for all the feedback, interesting opinions, mine will stay.
#26 ·
I have only dropped the chain twice in 3 years, but last week had a bad drop on a rough downhill. Dropped the chain, then somehow the chain bounced off the cassette and into the spokes. Rear wheel jammed, 3 broken spokes, 11 damaged spokes, bent hanger and trashed derailleur!
May put a top guide on, but feel it is really a freak occurrence....
#28 ·
Your bike doesn't need to have a single chainring or have an oval chainring. It depends more on the modality you practice. In trail or enduro, more bumps, jumps, vibrations can cause the chain to come off, this is where a chain guide should give you more security.
