What upgrade should I do on my Fox 36 Performance fork?
1 reading
22K views 21 replies 13 participants last post by  señortacotuesday
#1 ·
So I'm not really the most finicky of riders when it comes to my suspension setup. I'm riding a 2018 Hightower with an almost stock suspension that came on the bike (Fox 36 Performance Elite fork extended to 150mm travel / DPS shock), and honestly I've been very happy with it. Honestly, this Fox 36 is the best fork that I have ever owned.
That said, I'm starting to notice some limitations in my setup that make me think I should consider trying some upgrades. Things I'm noticing:
1) I'm not getting full travel out of my fork. If I soften the fork enough to get full travel, I get a lot of dive at the top, particularly in slower speed rock gardens.
2) When I have the fork setup so that it feels really good on high speed technical downhills, I feel like I am sagging into my travel quite a bit.
3) My hands are frequently getting sore on 2-3 rides. I don't ride with a death grip by any means, and I recently just swapped from the stock Santa Cruz grips to Deity Lockjaws, which I generally like. My hands also got sore with the Santa Cruz grips. I'll probably be trying more grips in the future.
I've been researching what my options are, and frankly as a non-suspension expert they are a bit overwhelming. Things that have jumped out are the DSD Runt, the Vorsprung Secus, Push ACS3, Vorsprung Smashpot and an Avalanche dampener cartridge.
So putting some boundaries on this:
1) I consider myself a trail rider. I'm starting to work on some jumps and drops, but nothing big. Our trails are definitely technical though, and like I said I am starting to work on pushing my limits. I do anticipate doing a few (2-3) bike park trips next year with my Hightower, but this isn't the driving factor for upgrading my fork.
2) I do care about climbing. If I'm riding down it, I generally ride to the top first.
3) I am currently running a 29x2.6 Rekon on the front and a 29x2.35 Agarro on the back. The Agarro currently has a Tannus Tubeless tire insert in it. I'm really happy with the setup in general, although I will probably switch the front tire back to a 29x2.4 Rekon in the future. If I really think it is limiting, I might consider a 29x2.4 Dissector instead. Our trails are generally pretty hard so I've never really perceived that bigger knobs bought me much and I hate slow rolling / draggy tires (see climbing comment above).
4) I currently weigh about 200 pounds. I'm hoping to drop some weight going forward - 175 pounds would be my happy place.
So what would people recommend for upgrading my fork? Should I start with the air piston (Secus / Runt / ACS3 / Smashpot) or the dampener (Avalanche / custom tuning)? One of my concerns with starting on an air piston upgrade is that I only have the basic GRIP dampener in my fork, so I don't have all of the compression and rebound adjustments available to fine tune the fork after I upgrade the air piston. Don't know if that is really an issue or not - might just be me overthinking it.
On top of all this, I really only want to do one upgrade at this point in time (by which I mean before next spring). So which fork upgrade provides the most benefit for a rider in my situation?
#2 ·
1 and 2 seem like you are unhappy because of some perceived need to use all of your travel or hit a particular sag point.
I think you should put your upgrade fork fund into a jar and spend it on something else. There's always something you can spend on, better protective gear, more comfortable clothes, a slick bike tool kit. Or just save up for your next new bike. Maybe rent a Shockwiz and make sure you have your bike set up just right for you.
I don't have a lot of experience, but I rode a Fox 36 Rhythm with the Grip damper and really liked the way it felt.
#9 ·
Honestly - I am open to this as a possible outcome. I'm not sure with a grip damper that Shockwiz will give me much useful information.
I do feel like there is some room for improvement, which is why I started this post. But I am also aware that this can go down a very expensive rabbit hole quickly.
#13 ·
I don't think I do, but I don't know how to definitively diagnose this. I will say that I focus on staying loose and relaxed, and if anything my tendency is to come off the front wheel a little bit when I get nervous.
Honestly though, I'd be pretty surprised if riding heavy on my hands were the problem.
Now, the 8-12 hours per week of tennis that I've been playing with my kids this summer/fall is a different story - for my right hand at least...
#12 ·
Is yours the fit/grip? Personally I think that's a great damper and servicing it is not difficult. I had the setup issues you had to some extent, I'm about 235 at my fighting weight. I got it to feel great on all except big hits, really big hits in which it blew through it's travel which was unnerving. I put in the push AC3 and it was a HUGE improvement all around. I'd say the damper seemed to work even better regarding knob inputs with the exception of high speed rebound. I switched to a grip 2 which solved the the HS rebound but honestly still feel like the grip fit handles compression duties better for aggressive riding.
Sent from my moto g(6) forge using Tapatalk
#14 ·
I'm pretty sure we are talking about the same damper - FIT/GRIP. It came stock on my 2018 Fox 36 Performance fork. I'd say when I am riding fast (75% of my full downhill speed) it feels great - really the bike as a whole feels great at speed. When things are slower is when I think that it starts feeling rough. And we have a lot of slower chunky trails.
I have watched the video for servicing the GRIP dampener and it makes me a little bit nervous. I actually do have two of the dampeners, so maybe I should take the plunge and try doing the service on one of them myself.
From the replies so far, I'm getting the sense that I should focus on the air piston side and just keep the dampener as-is for now. From what I've read, I'd probably lean towards the Smashpot rather than the ACS3 conversion if I went towards the coil, but the Secus doesn't seem like a bad option either. I've read that conversion to the ACS3 is a one-way deal since the spring will scratch the inside of the fork. Is the same true if you use the Smashpot?
One other question: If I can service the dampener myself, then I probably wouldn't send my fork into Fox for servicing, which means I'd likely burnish the bushings myself. Once you have the proper tool, is this a fairly straightforward task, or is it something that is easy to screw up?
Thanks to all for the feedback so far!
#16 ·
Grip damper or Fit 4?
If it’s a Grip damper, have you tried adding more HSC on the higher speed tech stuff, ie turn it clockwise.
I’ve had a few Grip forks, that damper is the real deal, infinite HSC, just need to find the sweet spot and frequency tune with your shock.
I have a rail damper Bomber Z2 on my backyard bike, it’s basically an open bath Grip damper, works great, add a 1/4 turn to firm up the ride.
If you really want to make that fork better, add a Vorsprung Smashpot coil kit with hydraulic bottom out, leave the damper alone, and you’re done.
#19 ·
new fox 36 performance 2020, i'd like to upgrade the damper
Hey !
I have a new Fox36 Performance '20 on my bike. I guess there is no point on selling it and buying a new one, if i can only upgrade the damper.
i'm riding hard, sometimes bikeparks, a lot of natural trails, sometimes with a lot of rocks.
What options do i have?
GRIP2
and now there is a new GRIP2 VVC ?
any other options?
worth it ?
#21 ·
Hey !
GRIP2
any other options?
worth it ?
Grip2 is a great upgrade, its not cheap but worth it.
