Can someone explain Fork flex: what, how, why, when, where...other than the obvious that the fork indeed flexes? TIA
Are you using disc brakes? That's most likely your fork flexing.LordDRIFT said:So If I notice, on hard front braking, my front wheel skews to the left...is that my fork or my wheel flexing?
Jayem said:Fore-aft. This is probably the least talked about, yet it is probably the 2nd most important. Small stanchions coupled with a small steerer tube/crown can lead to a lot of fore-aft flex. You may not notice it much, but there are quite a few pictures that show forks flexing during impacts. This creates binding and keeps the fork from absorbing the hit as it should. Having bigger stanchions only helps so much, and a good example of this can be seen with most long-travel single crown forks. Turn a 1.125 steerer marzocchi 66 upside down and you'll notice the steerer tube is so thick you can't even really fit a pencil in the space. They have to make it ultra-thick to give the stiffness and strength needed to support the fork. Everyone on the 29er board is crying that the latest 29er forks "only" use 32mm stanchions, and while bigger stanchions would be nice the fact that they're using a 1.5 steerer now makes a bigger difference in the fore-aft flex and is probably the primary reason they are using the 1.5 tapered system now. My point is that bigger stanchions only works up to a certain point and you have to do something else to maintain the fore-aft stiffness. With dual crown forks tehre's the entire 2nd crown. With most shorter-travel forks it's not a huge issue, but when the axle-to-crown length gets excessive, as with a single crown freeride fork or 29er, you simply have to do something to make it "stiff enough" in this direction. Another good example is the white brother's 150mm 29er fork. That thing SHOULD have a 1.5 tapered steerer, but instead it has to have a crown CNCed from a MASSIVE chunk of aluminum. It's not light and it's not an efficient use of materail, but it's what they have to do barring more expensive manufacturing processes.
Yeah, I was surprised to feel the Pike was very flexy after spending a year on a Magura Wotan.Bikesair said:It's very easy to detect after riding a nice stiff fork. My 32mm floats just can't hold a line in the rock gardens like my buddies 36 talas's.
That's not suprising, I have the same fork and the long axle-to-crown coupled with factors like fairly small crown, small/thin stanchions and 1.125 steerer make it possible. I don't know if you've looked at the steerer on something like a marzocchi 66 but it's super-thick.starre said:jayem - i have fore-aft flex in my 29er Reba fork from 2007. going over rocky stuff at speed causes a lot of vibration in the head tube area of the bike (sultan) and i can see the fork being pushed backward by part of the energy of impact rather than all the energy being transferred to stanchions action (my fork is not set up stiff). so maybe part of your argument about 29er forks is right. interestingly, the A to C of my 100mm Reba (505 mm) is similar or even shorter than most 140 mm forks for 5.5" travel 26" bikes with the standard 1.125 steerer tube (515mm). do they suffer from the same fore-aft problems? thanx!
Jayem said:The newer version of the Reba is supposed to be a bit stiffer, but in reality it's not going to be a huge change. The white-brothers forks have absolutely massive crowns and may not flex as much, but I gotta say that if I had a long-travel 29er I would NOT get a white brother's fork due to the extreme axle-to-crown distance. They make a 130 and 150mm fork, but at that axle to crown you can only beef up the crown so much and then you gotta do something else, like use a 1.5 steerer, bigger stanchions, etc.
