I want to upgrade my hardtail from 2x10 early next year.
The problem is I am not entirely sure where to go. I am also building a trailbike, so this one will be kept for all around general easy riding, and I just happen to ride on roads a lot, so I like the two chainrings system to keep the speed reasonable.
I guess the main question is shall I go for 2x11 or 2x12, but also can I ride decently fast on 1x12 when I am used to 38 chainring and am a strength pedaler? (I just hate the current seem_to_be trend of pedalling like a mouse in a wheel and it simply doesn't work for me)
I don't really need more speeds (although I am sure I could tell a subtle positive difference), so this argument for 2x12 is mostly irrelevant. The frame is also non-boost standard.
I don't want to spend too much money on this upgrade, and smooth shifting without much resistance is a priority. Is Shimano 12 speed a lot better than 11 speed, are they similar, or?...
Current setup is XT FC-M785 cranks and 38-28 rings.
Is there any way I could reuse the cranks for 11 or even 12 speed system? As if derailleur, cassette and chain weren't expensive enough, the cranks are just ridiculously costy, even if I go with SLX (which is probably the sane choice, given what, 30g difference between SLX and XT?).
What would you do and why?
