If you were to upgrade from 11-speed to the SRAM Eagle 12-speed, 10-50T vs 10-52T, which would you choose? Am I wrong, the newer 10-52T is actually less usable, because the extended range where it matters (climbing gears) is way less useful because of the big gaps. It looks like it'll actually make it more difficult to climb hills assuming that you already have enough range at that end of the cassette. Am I correct? What do you think? I'm leaning toward at 28T on the front with the older 10-50T cassette. Yes I want a 28T because I want to ride up 15-20% grades, as well as (occasionally) 15% grades with my preschool-age daughter sitting on her WeeRide bike seat in front of me.
This changes the way I climb hills. It would make me use the 2nd to easiest cog until I'm almost completely gassed, then at that point switch to the easiest cog which is a super-granny gear. Now its just super bailout gear instead of just the easiest gear. And I need to adjust my riding accordingly.
