As Nino is now racing a 120mm travel bike, you’d think that Scott would have a lightweight version for sale soon. Has anybody heard anything?
USNo way.. where are you?
I was told the same. The problem is getting the actual model and size you want. With only 200 Spark RCs coming to the US, that's divided between 4 sizes and 8 models. So if evenly distributed, there's maybe 6-7 bikes available ?. There's probably more of the common sizes/models, but still we're looking as extremely low stock across the US.A friend who is seeking a new Spark from a different source than me got an update from his dealer today. The bikes they expected in December have been pushed out to March 2022, no deliveries now in 2021.
At a certain point, bike companies will lose customers to those that can deliver. If my current 2014 bike frame breaks, I won't be able to wait. keeping fingers crossed that it will last through the next season. New bike day Spring 2023.I was told the same. The problem is getting the actual model and size you want. With only 200 Spark RCs coming to the US, that's divided between 4 sizes and 8 models. So if evenly distributed, there's maybe 6-7 bikes available ?. There's probably more of the common sizes/models, but still we're looking as extremely low stock across the US.
Have you considered mounting a 0-offset chainring to your exsisting X01 crank? 55cl cranks have a longer axle (and longer q-factor) I think? Going from a boost 3mm offset chainring to a 0mm chainring should give the correct chainline and not increase q-factor.Got my Team Issue today, plan was to swap x01 dub cranks but found out the new ones are dube wide with 55mm chainline, great....
Did you put your bike on a scale set up tubeless for a baseline?Weight of the size M team issue 11.7kg, with tubes in it.
Changed GX AXS cage to X01 aluminium one, that saved 64g.
Original seatpost weighs 300g, so that's a easy place to lose weight.
Original saddle 240g.
Original handlebar 339g
GX Crankset with 32t chainring 630g ( x01 with 36t chainring was 460g )
about 600g weight can be lost with just those bits without using fancy expensive stuff
I have Silverton SL's waiting to install to bike and waiting for xx1 CL55 cranks to be in stock again somewhere
With a decent carbon wheelset and x01 cassette about 10-10.2kg weight is pretty easily achievable. That's pretty good for 120mm bike
trs+ is not compatible with AXS, need the Helix, almost same price X01Did you put your bike on a scale set up tubeless for a baseline?
Also, I have nothing but good experience with trs+ cassettes and they are lighter than x01 and 50% of the cost.
I'm surprised to see the spread between frame weights so high. Your team issue is HMF right?
agreed, as it was my case. I wanted the new spark, but then with no stock in near future, i looked at orbea oiz, SC blur, ibis exie, etc. finally settled on specialized epic evo due to insight on availability.At a certain point, bike companies will lose customers to those that can deliver. If my current 2014 bike frame breaks, I won't be able to wait. keeping fingers crossed that it will last through the next season. New bike day Spring 2023.
May present problems for some to set up does not = not compatible.trs+ is not compatible with AXS, need the Helix, almost same price X01
The Path?I swung by my LBS they had a small 910 on the floor, seemed very light for the build spec and looked super clean in person. That headset wiring is very scary though, looks like a total headache and I don't see any positives.
The triple lockout felt really good and easy to hit all the levers. The SRAM flight attendant/AXS dropper would make these shorter travel bikes so clean.
Gorgeous!! Let us know what's the final weightHi there, got my new Team Issue 2022, did a few changes trying to get the weight down
I want to change the crankset but cant get the XX1 with the 55 chain line or Wide options any suggestion on how I can put a standard crankset in there?
Upgrades
XX1 cassette
KCNC seat post
Specialized carbon saddle
Syncros carbon handlebar
ESI grips
FOX 34 SC fork
