321 - 340 of 638 Posts
If we consider it a trail bike, is pretty light actually. For XC riding or racing it could be better, it's just ok I think. It is what it is.
That Roval wheelset is heavier than Silverton SL.
The top of the line roval control SL are about the same weight. They seem to have a great warranty though.
The Team Issue ASX does not come stock with Silverton SL, but a much heavier 2.0 wheel set ~1900g. The price point is also much lower for the Control 29 Carbon 6B and if you sell the stock rims, it could go towards half of the cost that could result in a sub 25 lbs. This is my plan. After the wheels I will probably replace the seat to save some grams and then seat post, with a light dropper at small weight penalty. Personally I think 25 lbs with a light wheel set is the upper limit for an XC bike that I look for and is probably the sweet point for cost vs weight these days. But who knows, maybe by the time I will actually be able to physically get one (like 2023) the stock SID forks of the 2023 will be lighter, fingers crossed. OR the ASX will get lighter batteries, who knows.
A
AXS
Weight of the size M team issue 11.7kg, with tubes in it.
Changed GX AXS cage to X01 aluminium one, that saved 64g.
Original seatpost weighs 300g, so that's a easy place to lose weight.
Original saddle 240g.
Original handlebar 339g
GX Crankset with 32t chainring 630g ( x01 with 36t chainring was 460g )
about 600g weight can be lost with just those bits without using fancy expensive stuff
I have Silverton SL's waiting to install to bike and waiting for xx1 CL55 cranks to be in stock again somewhere
With a decent carbon wheelset and x01 cassette about 10-10.2kg weight is pretty easily achievable. That's pretty good for 120mm bike
Envious of you being able to get one. Do you have a weight for the stock wheel set?
Agreed!
I would love to know the weight of the wheelset. i have a new carbon bar already for his bike, and he uses the 140g Tioga Spyder saddle, was also going to do an XG-1295 cassette, but was hoping to leave the 30mm wheels.
Anxious to hear how it rides!
Wow, that heavy!!! When looking for the weight of the handlebar i saw 250gr on some website. Buying the Fraser iC SL handlebar just got more interesting.
Handlebar 339gr + stem 150gr (claimed and probably 50mm) = 489gr. Fraser handlebar/stem 265gr. +/-224gr profit, hmmm :)
On the other hand you can get some 120g handlebars for 100€, that would be same total weight as that fraser onepiece :)
My zoom bars and Newmen stem.
$200 and 220 grams combined.
My Mt zoom seatpost and my 112 gram EC90 saddle on all my bikes.
$140 for 260 grams combined
Don't forget you need pedals to ride your bike.
OK ordered the Spark SL! Let's see how many months I have to wait... :rolleyes: :sleep:
Nino bike is 10.45 with pedals, my aim is to get same weight with pedals :) ( luckily he has dropper, that helps me )
You'll have to change a lot, starting with wheels, then all the other parts you referred above. Probably it'd be cheaper to buy the top model?
i already had Silverton SL wheels with xtr rotors and some other bits and bobs from 2020 Spark SL, so team issue seemed best option
At least you could order, none of the places on the east coast US I contacted are taking orders.
Making progress on making m 910 into a Super Spark. Added Lyne Amp 780mm bars, Lyne Amp 30 carbon wheels (2.5 degree engagement rear hub) with a Csixx Foamo insert in the rear tyre. Next upgrade will be a 150mm Oneup dropper which will fit at my saddle height when it is completely slammed. Also planning to get hold of some 170mm cranks for a bit more ground clearance. If I take this all the way I'll end up with a Grip2 damper in the fork and a DPS or Deluxe in the rear.
The store took my order, but nor they have an idea when will they get the bike. :p
Asia is still in covid lockdown from what I read... So this can take a while.
Trail bomber? Got some pictures?
I was just told today that I can put a deposit on a Spark RC Pro with an expected delivery date of September 2022 😕.
