Suggesting Transition bought a large batch of old faulty forks or that Spurs are ridden harder that other bikes with Sid forks?I've seens all sorts of SIDs for sale on pinkbike and they are usually the color that come on the Spur. Hmmmmm...
There is a batch of SIDS that have issues. Spur or no Spur. However on Pinkbike I see a lot of Sids for sale that came off a Spur.Suggesting Transition bought a large batch of old faulty forks or that Spurs are ridden harder that other bikes with Sid forks?
Yea sure. Just thought you had a theory of why Spur forks where over represented.There is a batch of SIDS that have issues. Spur or no Spur. However on Pinkbike I see a lot of Sids for sale that came off a Spur.
I probably saw yours for sale on pinkbike. [emoji16]I came to pretty much the same concluson. Thus i switched to the Fox 34 (non step cast) and have not looked back one second
I ran the 34 at 120mm intitially and upgraded to 130mm now, which i like very much on the spur!
I'm even tempted to try a 140mm airspring just to see if the geo will get too much out of place
the sid on the other hand went to Rockshox for warranty, and was sold after it came back.
Is it just that you want something fancy or do you have anything against the oem?Just bought one of those Bike Yoke Squeezy seatpost clamps because they do a proper 37mm diameter one which fits the Spur perfectly. Just went to fit it now and the titanium bolt snapped in two! My calibrated torque wrench was set to 3nm and the maximum torque spec on the seatpost clamp stated 4.5nm. Going straight back.
The hunt is still on for a decent 37mm seatpost clamp.......
The OEM one looks and feels a bit cheap and over time has started slipping a bit. I've tried the Wolf Tooth 36.4mm clamp but it was too tight a fit than I was comfortable with. Have been recommended the hope clamp but again, that only comes in 36.4mm. As far as I can see, Bike Yoke is the only well-known company doing a proper 37mm clamp.Is it just that you want something fancy or do you have anything against the oem?
Ok, good to know.The OEM one looks and feels a bit cheap and over time has started slipping a bit. I've tried the Wolf Tooth 36.4mm clamp but it was too tight a fit than I was comfortable with. Have been recommended the hope clamp but again, that only comes in 36.4mm. As far as I can see, Bike Yoke is the only well-known company doing a proper 37mm clamp.
Apparently Orbea now have some frames with a 37mm seat tube so hopefully at some point we might see other companies releasing compatible clamps.
No offense but I think you are to heavy, especially for the Sid fork. Shaving 30-50 lbs of yourself is going to make it much more fun climbing the nice bike that you have already. If you only ridden for 1 year I also suggest you start experimenting with tyres. Faster rolling tyres mage a huge difference, and per dollar spent it is no question that this is what you should start with. After tyres newer lighter wheels are next in line (these can also follow you to your next bike as long as you stick with regular boost and not superboost+ 157mm).Hello everyone,
Really considering the Spur as my next bike, but trying to determine if I have the right impression of who it’s for.
I have been riding for about a year now, with my first bike being a 21 Giant Trance X 29 2 that I bought used on a bit of a whim. I live in Indiana, and so far have only ridden within the state (favorite trails so far are Brown County State Park for anyone familiar). I’ve found I primarily enjoy flow trails and small jump lines, but also enjoy climbs and putting miles in on more XC oriented trails. Does this sound like a good fit for the Spur?
My Trance X has a Fox 36 with 150 mm in the front, and 135 mm in the rear. I love the geometry, but I feel as though I’m definitely over-biked for my area and skill level. I am enjoying the bike, but at some point feel as though moving to a bike with less travel and weight would make my rides a bit more exciting.
Right now, my biggest concern with the Spur is my size. I’m about 6’2 and 230 lbs. My goal is to get back down to around 200 lbs where I’m most comfortable. Any feedback from riders around this weight? Have you had to swap out the SID for something more substantial?
I’m 6’2” 205 on an xl spur. The great thing about the spur is it’s a very versatile bike, shorter travel with good geo. I’ve done everything from local xc series to a long day in Pisgah. My only gripe with the bike has been the Sid fork. Initially I had bushing play that was fixed under warranty, then my front tire washed and hit and tree at low speed (10-12mph) and bent the csu that cost $330 to fix. I opted for the pike which has a burlier chassis and sold the Sid. Hope that helps.Hello everyone,
Or Rocky Element with the Fox 34 - have had zero issues with the 34, unlike the 3 SIDs I've had with bushing playOr just get a ibis ripley; or trek for ex with a fox 36(on the trek only)
