Transition specifically says that they do not recommend a fork longer than 120mm. On the other hand, Ibis and Revel (the other 2 bikes I'm considering) both say you can over-fork by 10mm (or more). With 120mm out back, a 130mm fork seems like a natural fit.You can over-fork the new bikes with no issue.
Single pivot with flex-seatstays and a linkage-driven shock. It's essentially the same design as a Scott Spark, Specialized Epic, Kona Hei Hei, NS Synonym, and a few others, although that's not to say they'll all necessarily ride the same.Is it a single pivot design vs 4-bar?
That surprised me too, especially as the Spur seems to be replacing the Smuggler (for now, at least). I think it looks like a great bike for it's intended purpose, but I think there will be many people who will be looking for something more like the Smuggler or Scout that rides well beyond what you'd traditionally expect from a bike of that travel.Transition specifically says that they do not recommend a fork longer than 120mm. On the other hand, Ibis and Revel (the other 2 bikes I'm considering) both say you can over-fork by 10mm (or more). With 120mm out back, a 130mm fork seems like a natural fit.
I'd guess the Smuggler will reappear next year with the new frame design, maybe a 125 or 130mm rear?That surprised me too, especially as the Spur seems to be replacing the Smuggler (for now, at least). I think it looks like a great bike for it's intended purpose, but I think there will be many people who will be looking for something more like the Smuggler or Scout that rides well beyond what you'd traditionally expect from a bike of that travel.
The Spur definitely fills a niche but also leaves a big gap between it and the Sentinel, and I'm excited about what might fill that gap.
Did you bother to read or watch any of the reviews of the bike? It apparently climbs like a rocket and, at 25# for the high end spec, certainly doesn't seem heavy to me.I don't want to be too much of a downer, but it seems heavy, expensive, geometry that doesn't seem like it would climb great, yet it has limited travel so it wouldn't be much of a shredder on the way down.
I've obviously not ridden it and it could be one of those bikes that's more than the sum of its parts, but spec-wise, I'm not that impressed.
25# is ****ing heavy for a $9000 “xc” bike. Bet you the “low end” $5000 bike is pushing 30 pounds.25# for the high end spec, certainly doesn't seem heavy to me.
Well considering this is not a XC bike......it’s an All Country bike.....it’s not heavy. I agree it’s expensive, but for what the purpose of the bike is designed for and TR’s build quality when it comes durability it’s perfectly acceptable.25# is ****ing heavy for a $9000 “xc” bike. Bet you the “low end” $5000 bike is pushing 30 pounds.
Oooh inbound keyboard warriors raging in 3 ... 2 ... 1 ........it’s an All Country bike.....
