Surly Straggler
1M views 3.3K replies 313 participants last post by  mack_turtle
#1 ·
Holy crap, this is what I've been waiting for. Basically a disc Cross Check? The rear dropouts are nutty!
This will replace my CC, 100%
#1,724 ·
I having trouble understanding the straggler geometry compared to the cross check. If the bb drop is greater than how does it have a longer top tube? I am looking at it as if one were to increase the bb drop on the cross check the size would go up and the top tube would the same. What am I missing?
#1,731 ·
Quick question for you guys: is anyone else having problems with brake chatter on the front brake? I'm running TRP Spyres and my brakes shudder something fierce under moderate to heavy braking. The rotor is true and the pads seem to be aligned correctly. This has been an issue since day one. When I took it into my LBS that built the bike, I was told that road forks are going to chatter with a disc brake because of the forces involved. Thoughts/input? Would switching to a different fork help?
#1,738 ·
Well it seems like the stock fork isn't the issue, if none of you are having problems with brake chatter. I'm going to give it a thorough clean this weekend and I've ordered new pads as that is the cheapest solution. More info I didn't include in my original post: I'm using 160mm Deore rotors and my wheels are Velocity Ailerons laced to Shimano CX75 hubs.
LBS still thinks that the chatter is related to fork design. I generally trust my LBS as he rarely tries to upsell me, but I don't want to shell out for a new fork if it is clearly not the problem.
#1,741 ·
New Photos
Most recent evolution of my Straggler:
I joined the dark side and switched to drop bars. In order to do so, I had to swap out my hydraulic brakes to mechanical ones. Luckily my buddy had a pair laying around in his shop and hooked me up with these BB7 SL's for $50 a pop. So stoked. Since I am still running SS, I just picked up some SRAM S500 levers for now.
I think my next project is to try to convert it back to 1x10. I'll knock out the hubs, wheels, and tires last after tax refund hits my mailbox.
So far, I am liking the new set up. I thought I might be to stretched out with drops (90mm stem), but I don't at all.
#1,744 ·
Picked up my rad purple Straggler at the shop this weekend. Was able to ride it for a good 15 mins before the rain started and turned to snow, ending in 13".
But it was a fun-ass 15 minutes and she looks great in my stand in the basement! Can't wait to get it out and put it through hell.
I also put some 120 tpi Knards on it, so it anyone is interested in a take off pair of 27tpi, shoot me a message.
#1,745 ·
Anyone have a Revelate Tangle bag on their Straggler? I am looking at the sizing and wondering if I should go with a large or medium. I have a 56cm and measuring it looks like I'm right in between. Anyone have actual dimensions and or pictures of the fit on theirs? Thanks in advance.
