Seems all HS manufacturers have both HSs that can be used and adapters that can be used. Is this a new frame? If so, you could use a HS that is for 1 1/8 only, or a HS for tapered forks, but use an adapter for straight 1 1/8. If you think you may go to a tapered fork in the future, I recommend installing a HS for a tapered fork and using an adapter. I use an adapter on my frame with a tapered HT and HS (Cane Creek), and it works great.
