121 - 140 of 1,289 Posts
Put a Fox DHX coil on there, awesome shock and less than an EXT. Very easy to tune.
Cool thing about the new DHX is that you can change the stroke between 60, 62.5, and 65mm without taking it apart. So you can play with travel as well.
The 2021 Float X2 is the worst shock Fox has produced in decades in my opinion. If you don't have air in it already, you will soon...
How do you change the spacers without taking the shock apart?
Weather is interfering with my tuning, but I’m getting close. To increase small bump compliance and the ground hug I have decreased low speed compression and increased low speed rebound more than transition and Lars suggest, and added a
Spacer (2 total now) so I could lower air pressure a tad.
Still playing and will post numbers when dialed. I’ll just say in my opinion most people use too much lsd and not enough lsr. It won’t be as smooth as a coil though, but close.
Curious to hear when you get it dialed in. I am starting from Lars' settings as well, will definitely need to try playing with another spacer. You based in VT as well? Weather has been a bummer - I got out to Saxon Hill once during the two day period it was open, but other than that been doing repeats of chunky sections on some urban singletrack that dried out. Suppose this really isn't unusual for this time of year but the new bike has me antsy!
Yeah, and since you rode Saxon, you will understand weather isn’t the only thing holding back my tuning. Trails there are more like a rec path and even the “jump line” doesn’t offer much in the way of feedback. Trail work days are happening and fun stuff should be open soon.
I got a few days on some low speed tech climbs, high speed chatter, and some bigger hits- bottomed out the 38 with 3 tokens, Lars’s settings and 65 psi ( will need to add a bit there). I set the X2 to feel and confirmed with shock wiz on day 2. The wiz wants me to add HSC so I may up it one click. I’m 185 right now - in the AM and naked. I had no gear or bags on though.
190 psi, and two volume spacers
HSC 5
LSC 12
LSR 10
HSR 4
HSC 5
LSC 12
LSR 10
HSR 4
Holy **** that's soft on the fork. I'm 180 and I'm running 95psi. Having the bushings burnished on that fork helps a lot too. Would probably be 5psi lower without.
It’s a bit low, but with 3 spacers I won’t have to add too much more air. That jump I bottomed on is the biggest impact in the area and I intentionally landed harsh and it barely bottomed. I prefer my fork to be softer up top for high speed chatter and for rooty climbing comfort. That’s why I like 3 spacers. I think 70 psi will do it. Gonna pump it up to that and run the shock wiz for confirmation.
What were the Lars settings for the fork/where'd you see something listed?
Yeah, started with Lars, added a third token, opened up lsc a click to 2, and a bit of lsr. Fees pretty good, but will focus on that next ride and then see what the wiz says.
So what were the complete settings? The HSC/LSC don't do anything on this fork really, but curious about the rebound mostly. The LSR is a bigger compression adjuster than the actual adjusters because of the crossover.
I thought my 38 was good before, but now it's even better after getting it back from Fox with brand new lowers. I definitely have to run more air pressure now, by around 10 psi! I wonder if the damping was changed a bit too though.
So that's basically the manual recommended setting for the HSC/LSC (10/5), and a more open setting on the rebound, which is good (as I said, the crossover in the midvalve keeps the compression bleed by opening the LSR).
Damping wise I'm pretty much right on that, but the air spring setup just seems peculiar.
1 token w/90-95psi for my 180lb self (in gym clothes). Pressure dependent on the state of the bushings. Pretty well balanced with the PUSH 11-6 rear and a more aggressive clicker setting.
It’s a bit peculiar, as am I. I set my sus a bit differently than everyone I ride with, but I have converted a few. I am very active on the bike. Years of bmx as a kid and old school 80’s dirt jumping may be blame. I body movement through chatter and/or time airs to smooth out trails. This is opposite to what a lot of moto guys do. One friend I ride with has a pure moto background. He tends to be heavy on the bike in chatter, and becomes more active the bigger the features. Neither style is really better or faster. We are the same size, he uses fewer spacers and more air for a more consistent feel through the travel and a higher effective spring rate in the upper part of the stroke. We swap bikes occasionally for comparison. Our mid stroke support feels the same but neither cares for the others top end feel or ramp up at the bottom. I like less compression at the top end for my style, and more lsr, which will likely get a click or too more to be dialed. As I’m more active in chatter and at faster speeds I want more give and for the fork to push the fire back quickly. Plus a bit more lsr helps with pop and getting airborne quickly.
The traditional use of spacers is “set your sag and add spacers if you bottom out.” I set it for feel at the top and add spacers for end stroke support. There’s a good description here about adding spacers and reducing are a few scrolls down;
I bet they just sized the bushing correctly so the fork now has way less friction. Makes sense that it requires more pressure now.
What was it sent it sent in for?
I bet they just sized the bushing correctly so the fork now has way less friction. 38's are typically the worst I have seen in terms of tight bushings/friction between CSU and lowers. Makes sense that it requires more pressure now.
I thought it was really low-friction to begin with, so idk... I am now able to use full travel more easily and the fork is overall even smoother. It was sent in for bushing play and a damper service.
Works Connection angled headset installed for 63.4* HA, 70.3* SA, 809mm front center, 448mm rear center, and 342mm BB (low position). ZEB @170mm w/ Vorsprung Luftkappe, Marzocchi Bomber CR coil (Avalanche tuned), and Cascade link.
The shorter/steeper front is much better on the trails, but still a monster descending with the low BB and long rear. More balanced where as before the front wheel was a bit too far out there. Very happy with the beast now. (y)
How do you like the luftkappe? I’ve got a dsd runt in mine but the luftkappe is intriguing.
Are those the trp 2.3mm rotors you’re using with the saints? If so, good to know that can work
