2,181 - 2,200 of 2,637 Posts
Hello everyone. I'm just about to finish a deal on a new Chisel Comp 2021 for around 1200usd, which I think is a great price. However I have a couple of questions for you guys: would it be possible to swap 1x for a 2x Deore drivetrain? I'd like to take it bikepacking and the extra gears would be very beneficial on flat terrain. Does anyone have experience with this? Also, is Recon Gold with Debon Air better than stock Judy Gold with solo air? Recon is 32' stanchions and Judy 30, would that help with the flex some have written about? SIDs are out of my budget but I see great results for those who have posted here.
From what I have understood 2x drivetrain is not possible. I thought I would want 2x gearing too and that was requirement when I bought my gravel. However, did a week long bikepacking trip in Spain and felt fine with the deore. Terrain was mostly going up and down so if mostly flat it could be different. Personally I think the Judy Gold is only suitable for gravel. I weight arround 80kg and the fork felt way too flexy and didn’t have necessary support. Recon should be at least some what better. I changed to SID which was great as long as it worked. I have now returned two SIDs an got a refund. Manitou Pro would most likely be great, but is too expensive so I don’t have a fork now. I have also considered the Recon and Revelation as budget options.
I seriously doubt the seat tube is designed to handle a front derailleur and think you would destroy it under the derailleur.
I also think the fork flex you are concerned about is pretty much non-existent and really “internet-bro I’m such a badass on a bike that anything under a double crown dirt bike fork isn’t able to keep up with me on my 26 pound XC bike” stuff.
Take everything you see on the internet with a grain of salt, including this post. Unless you experience it personally or an actual, meaning not via internet or social media, friend experiences it, I would not put much stock in it.
Yes, worth trying the Judy personally. I didn’t believe to the flex either and can’t notice it in the SID or Fox34 compared to my Zeb. All these in different bikes and usage of course.
Might be that the Judy did not flex and it was only the damper I was unhappy, but felt it was even worse when turning. Best to try it your self and decide then.
And no, I’m not a badd ass. Just a normal 40-yesr old guy with three years of MTB experiene and on the slower end. For Chisel I’m not even looking to hit the downs fast as I have better bikes for that.
If you don't mind going up to 120mm travel you could get a good deal on a Reba RL takeoff on Pinkbike. They look to be selling for around $200-300 right now. I have been riding one on my chisel for a few years now and like it a lot better than the Judy. I can tell that it does not flex quite as much as the Judy, but also a little more plush. Still has the Motion Control damper, which is not my favorite, but it works well as long as you stay out of chunky trails.
My frame is coming light blue (gloss chameleon/arctic blue) frame and most of my build ordered! Obviously stem length is personal but what are people running on these?
it depends on personal preferences and riding stype - for racing XC or just going fast uphill and on flat you can go longer than 80-90mm and 17 and above degrees negative raise.
Also if you have longer hands or height for the frame - for example M size is from 165-178 - if you are 177 you can go for longer stem
Hi everyone, I just purchased new chisel 2023, In the carton box, it appears that my bike is size M, however, I see the tube length of my bike is more shorter than the M size. Could you please give me some advices? View attachment 2028321
I won't confess to being a geo expert, but there are a few questions that stand-out. Which tube are you referring to - top tube, seat tube, down-tube? From where to where are you measuring from and does that measurement (starting and end point and angle) match the Specialized geometry chart? Perhaps more importantly, how does the bike fit you - are you in a comfortable position, not too stretched nor too cramped? If it fits and you are comfortable then the tube measurement is an irrelevant in my opinion. I would also look at that front hydraulic hose routing which seems quite "looped" and an accident in waiting and risk of getting caught in the spokes.
Hi, had the chisel for a while and in the process of changing the fork to a Fox 34SC. The original wheels do not fit though which is a first for me and the hub ends are like large discs that fit well into the RS Judy. I'm guessing I need to adapt them, but cannot find specific branding.
A bit of googling, and I've found this, :- Specialized S205900002 EDC Front L/R Set TA 15x110mm 19mm OD
Looks the part but wont know till fitment. Anyone had to deal with this or know the correct kits?
I reckon you have the 15mm torque caps which are specifically there to help improve engagement with the Rockshok forks. Not essential per the below link. So imho you just need the "standard" 15mm end caps.
