Specialized Chisel discussion
998K views 2.6K replies 383 participants last post by  msrothwe
#1 ·
#11 ·
What do you think about it vs the fuse?
Depends on your goal. Chisel will be must faster and lighter in good/smooth conditions. Ive seen an almost stock fuse weigh in at 28 even pretty much. The fuse in rocky rooty areas is nice and it "climbs like a billy goat" but is definitely slower in some aspects.
#34 ·
From what I understand, it seems that the Epic HT alloy is going away (as it was really just a renamed stumpjumper frame rather than a new frame) and the chisel will be taking its place.
The Alloy Epic HT is not boost anyways, so i doubt they keep it around. Unless they boost it and go with an even better smartweld frame for that one... There is no reason to keep it around.
#44 ·
I think they should have gone with 24-38 rather than 22-36 on the Comp chainrings. Too easy to spin out the 11-36 cassette with a 36t outer chainring. If this is a racing hardtail, which I think it is intended to be, people will be getting passed on the flats IMHO. That appears to be my only significant grind with this bike. . . . from what I know so far. Looking at you Judy. . . . .
