Here at MTBR, we’re big fans of Silky saws for light-duty trail work. Compact, capable, and far quieter than a chainsaw, they’re well worth stashing in a pack to clear deadfall or handle quick trail-side cleanup.
Now, Silky has released updated versions of its two largest folding saws—the Katanaboy Professional 550 and 700. Designed for serious trail maintenance and remote backcountry use, both models get redesigned handles, improved ergonomics, and high-strength, re-sharpenable blades.
Highlights
The new Katanaboy Professional 550 and 700 are designed for cutting large limbs, thick branches, and full logs in remote settings where powered tools aren’t an option.
Both models feature long, taper-ground blades with impulse-hardened teeth, designed to make fast work of dense wood with smooth, efficient strokes. The updated handle design improves grip and durability while reducing fatigue during extended use.
The Katanaboy 550 uses a 21.6-inch blade and is rated for logs up to 11 inches in diameter, while the Katanaboy 700 steps up to a 27.5-inch blade and can handle logs up to 14 inches thick.
Both saws use Silky’s XL tooth design, with aggressive spacing to speed up cuts in hardwoods and wet material. The blades are nickel-plated for rust resistance and can be re-sharpened.
Improved Storage and Portability
Both models come with new carrying cases made from lightweight synthetic fabric. Each case includes a hook-and-loop closure and internal storage for replacement blades. The 700 model’s case includes a shoulder strap for easier transport during long trail days or wilderness work.
More information on the Katanaboy Professional series is available at silkysaws.com.
Highlights
- Katanaboy 550: 21.6” blade, 11” cutting capacity, $351.99 MSRP
- Katanaboy 700: 27.5” blade, 14” cutting capacity, $434.99 MSRP
- Redesigned handle for improved strength and ergonomics
- Lightweight, re-sharpenable nickel-plated blades
- Comes with new synthetic carrying case with hook-and-loop closure
- Made in Japan
- Available now
