So I’ve added a 4th token and dropped 5psi as the wiz told me. Took it down the same trails and it still wants more air reduced and add a further token. Which is not possible to do as I’m at maximum tokens for the fork.
I decided to ride a trail today, which is renown for technical climbing and very technical rock garden descents, roots, berms, it’s all there basically.
It’s the first time I’ve rideen the magic Mary on bone dry hardpack, but something just didn’t it feel right. The wiz is still telling me to drop more air and add a spacer. In the chunk it felt ok, but in the fast berms it was nervous. I am not sure if some of that was attributed to the Mary not gripping as well as my long standing DHF use.
Does anyone have any suggestions on what the next steps should be. I am running no LSC as per suggestions, it’s green, as is rebound. EDIT: it’s LSR and HSR that are green. LSC says make softer, which it is already open.
Dynamic sag is fluctuating between 6-15%.
I have had dynamic sag at 24% once but only at 49% confidence.
All other suggestions are at 79-100% confidence. Im taking screenshots immediately after every DH run
I’d like to blame the tyre, but I’m not sure where the wiz is taking me?
It’s suggestions are consistent. There is some fire road pedalling in the mix, but not much.
Thanks again.
Just to note, my psi increased at one point from the base 75psi to 81.6 on a long DH run, although that may have been me slightly resting on the bike. I was knackered
