Hello mpress,
Great question. There are two ways to handle this.
1) You either ignore the suggestions you don't have adjustments for and instead focus on getting those you do have control over right. This often corrects those you don't have control over.
2) You send your suspension back to the manufacturer or suspension specialist to have the stock tuned changed, if applicable.
As an FYI, the best way to start riding with ShockWiz is to set all your compression adjustments to full open or soft, and then go ride. This puts all the focus on the spring (Baseline Air Pressure and Air Spring Ramp). This gives ShockWiz a very unrestricted view of how the spring is working and what it's capable of. If after the ride you have Suggestions to change either Baseline Air Pressure or Ramp, make these first and retest to ensure they indicate 'OK' before adding any compression adjustments. I recommend checking out this article about Tuning Order found
here.
If after following the correct tuning procedure, the adjustments you do not have control over do not move to "OK", you either continue to ignore as your suspension is probably performing very well at this point, or you can look at having the stock tune changed.
If after numerous Ride Sessions ShockWiz is always asking for softer HSC, you could have your HSC shim stack tuned softer (same goes for firmer if that's what it's asking for). This would need to be done by a professional which probably means sending it back to the manufacturer or specialty service center, but the upside is you have data to back up the need.
In the end, I wouldn't get too bent out of shape if you have a yellow indicator for something you lack an adjuster for.
A config-urator has been considered for omitting and including adjustments, it remains to be seen whether or not we will provide this.
If you saw a negative travel percentage it means you marked Baseline Air pressure, and the actual pressure in the positive chamber dropped slightly. This most commonly occurs if the negative and positive chambers did not full equalize prior to marking the baseline pressure. Re-marking to re-zero that value out is the correct thing to do.
Alex@Quarq
