Knowledge is power! Just because an adjustment cannot be made easily, does not mean it cannot be made. Granted it may mean you can't do it yourself, but I still think it's better to have that information that to omit it. With the information at hand you have actual data backing up the need for said change which, if it requires a suspension center or the manufacturer to perform, further justifies the need to send it off. [/INDENT]
Alex@Quarq
I feel that this is a great statement to be quoted in regard to the HSR feature
I´ve played with this device for the last 4 days in Finale Ligure. On the first 2 days, I only let it monitor my fork settings without changing anything to get a good impression on how my own setup performs against the data.
I used "agressive" and the findings/"Suggestions" were mostly as estimated as I tend to ride stiff and progressiv springs on the front. What also correlates with my personal impression is HSC statement. I somehow always under the impression that forks are verry overdamped in that department...:
- Remove Air -> red
- Remove Spacers -> yellow
- Rebound OK -> green
- HSC make softer -> yellow
- LSC OK -> green
- Bottom Out Resistance - Remove resistance -> red
Detections -> all OK -> all green
Dynamic Sag -> 28%
Does someone have a scientific opinion about the "dynamic sag"? How much should it be? What conclusions can be drawn out of this measurement e.g. what impacts on the general riding impression do smaller or larger figures have?
I tried to lower the pressure for day 3, but as I were already pretty beaten up after those two days, I got somehow scared by the increased dive and returend to the higher pressure again.
So my current conclusion is, that I might have to take a different approach to this. Maybe I shouldn´t start the tuning process with 4 tokens as the resulting ramp and bottom out resistance seems to be issue. Also I might need to rethink handlebar hight?! I absolutly don´t want the fork to bottom out but maybe I shoul try to use more travel and compensate for the lower "dynamic stack" by using more rise on the handlebar?!
Also, I now think, that there is no way arround internally retuning HSC...
Btw.: If I switch to "Playfull" all suggestion turn to green except HSC "make softer" -> yellow, so the first finding is, that there is quite a huge difference between tuning styles.
All in all, it seems to be a nice gadget and it is very intersting to get an "external feedback" about the settings. Also the fact that it confirms my own feelings is a sense of achievement
It is also interesting to see, that it is possible to achive "all green" in "detections" with 2 to 3 red bars in "suggestions"...
After toying with it, I must say, that I´m also interested in the possibility to access more raw data and for what it´s worth... I´ve never had a single issue with the bt-connection no matter if bt was already on before I started the app or if I turned it on after the app was already started.
EDIT: Once it wanted to do a firmware update although the latest version was/is already installed. Don´t know why this happens...
