Ripmo V3
6 reading
254K views 1.3K replies 159 participants last post by  ColinL
#1 ·
Inspired by the previously created Ripley V5 thread, what input or ideas would current or previous V1 and V2 owners give to the design team over at Ibis for the next iteration?
Things that I ponder...
Will Ibis ever incorporate adjustable geo into their line up (i.e- Ride-9, etc). I also like the concept of in frame storage (i.e.- Trek, Specialized SWAT, etc).
I personally like the look of Ibis bikes, but wonder if anyone thinks a change to that swoopy top tube would be ideal.
What say you?
#1,194 ·
All my personal opinions/observations below:
I'll call it a long legged trail bike.
  • Dont think the Float x as tuned or spec'd is the best option. Much better w an off the shelf RS SDU. Just installed a Vivid yesterday and too soon to give a review of the Vivid/Ripmo.
  • Efficient on the pedals but dips into travel easy at sag and has great traction on the tech bits. If you have to pedal it's an ibis!
  • its not clumsy on tight bits and I find I can put the front wheel anywhere I want on tight and tech trails.
  • it does ride with a more firm overall feel than you'd maybe think a 150 travel bike would - doesn't erase the trail - lets you know what's happening but in a pretty good way
  • - - yet its very capable and it is definitely smoother on the choppy/chattery trail bits than my v2 and Alchemy, maybe doesn't "swallow" the chunky square edge stuff as well as other 150 bikes but also doesn't hang on em - still holds speed well. (my alchemy would tug like a quick brake was applied)
  • I feel it rewards a more active ride style IMO - it will pop off small lips and features so easily
  • - - I feel like if you are a hold on and plow type rider you may not get as much from it or like the more firm feel
  • my overall best rides have been right at 29/30% sag. Ive run less and run more and each offers respective plus/minus in feel for doing so. All subjective tho and YMMV.
  • I have no regret getting it even w some negative reviews online etc... it's a great trail bike thats working well for ME and the techy/janky blue/blue black/black I normally ride. It's better/differnt than the previous Af/V2. I demoed a bunch of bikes. this was the one I did not. I also bought w the perspective that I could potentially have a Ripmo OR a Ripley. My buddy bought the Ripley build version. gettin on with it well on same trails.
I demoed - Smuggler, Rascal V2, Yeti 120 and 140, newest Switchblade. All good bikes and nice to have so many options that I DIDNT get to even demo. IMO feels most similar to Y140(but I didn't jive w that one at all - still similar suspension feel IMO). Smuggler was WAY more "nervous" in similar dh/rocky scenarios (as you'd expect) yet Ripmo just as efficient/fast on the pedals uphill and better tech traction over techy ledgy features (seems Smug suffers from a similarly questionable float x tune and better results w other shocks). Switchblade was the eye opener - didn't expect it to be as plush/soft feeling yet very capable and controlled. I was expecting it to be the firmer feeling of the longer travel bikes I demoed and even vs the Ripmo - yet it really wasn't.
#1,207 · (Edited)
My new Vivid air valve faulted out pre-ride yesterday. Shop fixed it quick, but to make sure I didn't miss the ride opportunity I quickly mounted the Float X (could thrown my SDU on but I had pressed mounting bits out and used on the vivid). It's ok - but boy - that "nervous" feeling thats been mentioned re-emerged. Vivid goes back on asap EDIT - no bueno upside dow as piggyback res would stick out to the side
#1,217 ·
147lbs kitted here, running 140psi (30% sag). Agreed on the 'sporty' description, but would also say it's pretty smooth over small bumps (compared to previous frame that was a Stumpy Evo with an e-Storia, but i ran 28% sag on that). I guess the light tune on the Float X works better for us lighter riders. Not running a Fox fork so no issues with the front end for me.
I do have a coil shock on the way, though, looking forward to seeing how that rides. Had one on my previous frame and just like the way coil shocks feel.
#1,220 ·
Not enough competing viewpoints. Either their preferences are too similar, or their opinions are too easily influenced by each other that it becomes an echo chamber. Levy's love for XC added meaningful insight because for most riders without access to big mountains or uplifts, our priorities in a bike are not 90% (may be exaggerating here) focused on how well it descends.
I still enjoy their videos for entertainment, though.
#1,222 ·
Fox suspension feeling great to me. I’m one of the lighter riders. More evidence maybe that the Ibis/Fox tune benefits us (I’m basically identical weight to mtb yumyum Jason, 140 pounds - who also likes it). Float X feels good all around, smooth, excellent support. Running no spacers which helped for sure. I also bought a 36 Grip X fork and it feels equally good.
FWIW My frame was the Ripley (I’ve done the Ripmo conversion so have both) and the Float shock feels equally like a solid match for the frame. Pretty amazing what that 140/130 can do.
#1,223 ·
I’m starting to think that fit is super critical, and is often understated in reviews. The difference between riding a bike too large or too small for you makes a big difference and I think when you see disparity in reviews there’s likely a bunch of differences between reviewers in fit to the size they are testing and potentially in setup for their weight (ie volume spacers, etc). I wish more reviews provided more data on rider fit and bike setup so you could use it to supplement the comparison of opinions.
#1,224 ·
Anyone have luck mounting the Vorsprung Telum on an IBIS Ripmo XM frame?
I built my Ripley into a Ripmo V3 with a 170 coil fork and RS air shock and liked it enough to get the Telum for a full coil set up. Unfortunately, I haven't been able to get it installed. The Telum front eyelet is much larger than on the Fox/RS air shocks and it impinges on the frame before the bolt holes can line up. After talking with Ibis and Vorsprung, looks like I'll be shopping for a different shock. 🤷‍♂️
#1,225 ·
Maybe an offset shock bushing in the front of the Telum would let it work?
#1,226 ·
So after around 10 rides on this bike I take back some of my words. After about the 5th ride, my Grip X damper starting making a very loud hollow clunking sound. I'm not sure if that's the same noise other people are complaining about, but it's so annoying that I have to do something about it. My first thought was to just replace the damper with a Grip X2 as that would be the cheapest solution. However, there's some other drawbacks with this bike that make me want to take it a step further.
I love how efficient the bike pedals and how it feels on flow trails - easy to climb and feels supportive for pumping on the descents. However, it feels harsh and skittish descending down technical trails, especially on trails I'm not familiar with. This is an issue because I try to ride a lot of different areas and I usually favour riding tech trails over flow trails, but I still want the bike to climb, pedal, and pump well.
I've had to go down a volume spacer in both the shock and fork to get full travel. I would say my suspension settings are pretty average, so nothing out of the norm to affect the handling of the bike in a negative way. I have 30% sag in the rear and around 20% sag in the front. My current settings for my 175lb riding weight are:
Factory 36 Grip X
  • 1 volume spacer
  • 85 psi
  • 10 LSR
  • 7 LSC
  • 9 HSC
Factory Float X
  • 0.3 volume spacer
  • 215 psi
  • 8 LSR
  • 5 LSC
I'm now debating whether to go back to an HD6 as that bike was very efficient, in spite of it's travel. However, I already have a big travel mullet bike for park days, so I'd prefer something more All-Mountain oriented (if this is still a term), which is what, in my opinion, the Ripmo should be. I feel it behaves more like a short travel trail bike with it's current suspension, which leads me to wanting to purchase a different fork and shock, but with the same travel. Like maybe a Zeb with Vivid Coil/Air or a Lyrik with SDU. It really sucks I need to spend more money in hopes to make this bike feel like a better "all-a-rounder".
I've heard the Vivid feels really close to a coil, but with slightly more support. However, I'm more curious to know what this bike would feel like with a coil. I had a Firebird with a coil and that bike still had lots of support for pumping and still climbed well. I'm thinking with the Ripmo being a DW-Link bike as well, it would still offer plenty of support with a coil and still climb decent too. There doesn't seem to be many people in this thread that have this bike with a coil shock, so anybody that does, can you please share your experiences as far as mid-stroke support for climbing and pumping, and end-stroke ramp up on bigger hits?
#1,229 · (Edited)
Factory 36 Grip X
  • 1 volume spacer
  • 85 psi
  • 10 LSR
  • 7 LSC
  • 9 HSC
Factory Float X
  • 0.3 volume spacer
  • 215 psi
  • 8 LSR
  • 5 LSC
Yup. Pretty much what I've been saying about the Ripmo for a couple months now. I tried a full Rockshox suspension on the bike, as well as two custom tunes on the Fox stuff (with the last tune being an extremely soft, low compression tune that the shop had developed for a light, female enduro racer). Those options did improve things a bit, but none of them got rid of the fundamental harshness/twitchiness of the bike. I'd be curious what a coil setup is able to do but not super hopeful.
I also got a Ripley clevis and shock and have been running that setup with a 150mm fork. It feels better than the Ripmo. Smoother and less nervous, and not noticeably less capable. Ridiculously low BB height tho (lower than my XC race bike).
#1,236 ·
I can't believe I didn't think about this earlier. I can swap the suspension that's on my Status to the Ripmo. This way I can try a coil shock with a 170mm fork before buying all new suspension and then maybe finding out that I still don't like it.
I can't wait to try it! We had an amazing January (Juneaury), but now we got hit with a cold snap, so I may not be able to report back for a while.
