I am moving ahead with my new wheelset project and need a bit of advice/info/opinion. Here goes:
Rim to rim, given a constant width, it is safe to assume that a deeper/taller rim will be stronger?
When chosing a rim with weight as a predominant factor (aside from ballpark dimension), a rim that requires a shorter spoke will save weight. It will also make the wheel stronger and stiffer as less spoke is used?
What is the advantage of welded vs sleeved/pinned joints? (I obviously can think of a few, but would like to hear experts' opinion). I ask because it will help narrow down choice.
If a spoke calculator calls for 268.8mm spoke and the choice is between 270 and 268, going with 268 is still safe?
_MK
_MK
