Reverb is sinking a tad when sat on
34K views 19 replies 12 participants last post by  simons95
#1 ·
Stock on a new Sentinel. You can just stand beside it and push down to feel it drop maybe .25". That's not affecting anything but I'm guessing it's just gonna get worse.
Is there an easy fix or do I need to have my LBS service it?
#19 ·
Newer reverbs are way more durable than the old ones. Mine lasted a full year and a half of heavy riding and abuse before needing an $80 rebuild.
First gen I went through like 2 or 3.
To answer the OP - if its sinking suddenly, it likely needs to be serviced. Air still gets where it shouldnt be over time with these posts.
#18 ·
Good video. My LBS warned me when I got a bike in 2016 to never pull up on the reverb when it was in the down position.
My new bike has a round top tube I clamp to and avoid the seat all together. This Stealth has shown zero issues in over a year, feel like I won the Reverb Lottery! Or, more likely, that's just how the B1 posts should be.
#16 ·
I wouldn't necessarily think so. My Reverb started acting up when it was just a couple of months sold. In my case, I'm pretty sure it was due to using it as a clamping point for my stand. Since corrected, and now that I no longer use the post for clamping, no more issues. A rebuild wasn't required.
#14 ·
Correct, and that's what I do. But with the Reverb, seems even extended can cause issues. But to be honest, I don't just hang the bike in a balanced fashion all the time. That doesn't help, and is why I (now with droppers) always clamp to the frame.
#9 ·
My Reverb started doing the same thing... corrected it... started doing it again. But never really an issue, and it doesn't seem to get worse. BUT... after the second time getting it fixed (method like Lone Rager mentions, BTW), I stopped using the seat post for mounting to my bike stand (as recommended by the RockShox). The issue hasn't returned.
#6 ·
^^^ right. Bleeding the remote does nothing for sag as the remote circuit is completely independent and not fluidically connected to what goes on in the post.
It's common for Reverbs to sag several mm when weighted. If it's significantly more than this, one trick you can try is to extend the post, turn the bike upside down, squeeze the remote and press down on the BB to compress the post. Release the remote, turn the bike right side up and then squeeze the remote to extend the post. What this does is move the air from the IFP tube into the reservoir. It's still on the wrong side of the IFP, but not in the IFP tube where it will compress when you sit on the saddle. This is a temporary and imperfect fix as the air will eventually get back into the IFP tube and cause squishiness.
#8 ·
I'll check the air and I'll also give this a try but I'm more than a little perturbed that it may need service after 409 miles...
