Long story short, new bike, came with CODE brakes, I only know shimano, no bleed kit or parts to maintain SRAM stuff. I replaced the pads because the OEM's were no good, and they are slightly thicker, so they rub on the rotor. Looks like the bike shop overfilled the brakes.
I believe I need to pull some fluid out. easy for shimano, put the cup on the caliper with some fluid, open up, and squeeze some fluid out and seal up. GTG. I don't have a bleed kit for SRAM and it looks to be rather expensive, so I'd like to avoid getting it for my new brakes till it's time to bleed.
Is there a process I can use to pull a few drops of DOT fluid out of my brakes without risking getting air in the system? no hardware to get airbubbles out if I do it wrong.
I'd really like to avoid getting a bleed kit for another year.
