PORN ----- naked Moulden
3.3K views 26 replies 11 participants last post by  bushpig
#1 · (Edited)
I just got it back from my stripper (ooh, this is porn;)). It looks good, I can't see any stress cracks or problem areas :thumbsup: . The filleting has some tiny "air bubble" holes that I'd like to fill, anyone have any ideas how? It's gotta be a metal based filler as I'm going to powdercoat it Gloss Metallic Black. Sorry for the lousy pics, I'll do better later.
And a question...are filleted frames tigged first and then filled or is the filleting holding the whole thing together? I guess I'm wondering if filleting is kind of like soldering?
#4 ·
looks neat. I like the canted rear dropouts like Ritchey did. Those little air pockets are normal. I think theyre from impurities in the brass if I recall. You can fill them in with a touch of bondo if youre gonna use wet paint or maybe some solder if youre gonna PC.
and yes, the brass alone holds it together. no TIG underneath.
#9 ·
Bondo is sorta overkill for those tiny spots. This stuff is much, much easier to work with...
http://shopping.msn.com/specs/shp/?itemId=671561262
#11 ·
that's what I thought....
grawbass said:
Actually those fillets aren't bad at all. I wouldn't want to clear coat it, but under paint, they'll look fine and the size and radius are good.
I'm certainly not an expert but I thought they looked pretty good too. I like the proportions of the fillets relative to the tubing size.:thumbsup:
#13 ·
banks said:
Too bad it looks like the blast media was too big/coarse.
What do you see/why do you think so and how can you tell?
He's done 4 other frames for me using the same procedure and they came out great.
#25 ·
Stan, If your powdercoater is nice have him build up the areas that have the air bubbles or pitting with a thick pass of powder coating. After those areas are filled they are then sanded down flush. Then the final coat is applies and viola!! SMOOOOOTTHHHHH.
