We've teased it long enough, we've finalized things well enough, that we think finally time to openly talk about it.
Still another 1.5-2 months (As of March 2022) till we can actually start shipping since we have to prioritize Evo and Hangover production in our PCB scheduling since we are out of those thanks to the IC chip shortage and needing to tweak the boards to work with different IC's. Though our hard parts are finalized, things have been tested, the beam pattern tweaked to perfection, and production has started on those parts. So with that in mind... Ta daahhhh!
DETOUR
The design brief for this was pretty simple. Take the Road Edition that many people loved, and make it wireless. We have decided to target this as our "middle of the range" light for road/gravel bikes. Meaning that it has a single 21700 Samsung 50E 5000mAh battery instead of an 18650 that's found in Hangover, or double 21700 cells that's found in Evo. Runtime is around 2 hours on high, 3 hours on adaptive. Lumen levels is around 1100-1200 which is actually less than our outgoing Road Edition, however improvements in the beam pattern control, efficiency, and being able to have the freedom to design the light around the reflector itself rather than the shell like in Road Edition, means that we have a MUCH better beam pattern and more throw. The light carpet improvement is truly one that you have to see in person to believe, pictures aren't capturing what a tremendously huge difference it is.
Here are some photos comparing the new Detour to the Road Edition:
As you can see, MUCH wider field of view, and a lot more lit up in front of the bike near the tire. The photo might make it look a slightly bit blown out near the leading edge, but rest assured in person the effect is not noticeable. In fact part of our delays to launching this product was because of two tweaks we needed to make to the reflector to perfect that beam pattern for a truly seamless riding experience.
Even though it is technically two different beams blended together, much like a lot of stvzo compliant cutoff beam pattern lights out there, I've been absolutely obsessive about making sure that the distribution on the ground is nearly perfect. Nothing annoys me more whether on a bike or in a car then having weird artifacts or dead zones in a beam pattern.
Same USB-C quick charging, same USB-C cables, same pass-through performance as all our other lights. It also uses our quick release mounting mechanism that we've been successfully utilizing on the Trail Evo and constantly making improvements to. We know that there are a lot of weird aero bars and strange handlebars coming out in the market so we have invested in a new Formlabs Fuse 1 SLS printer so that we can bring more custom mounting solutions in house. As we build up those mounts we'll launch them on the site.
For those with bike computers, we have a modified version of the quick release mounting shoe that has the gopro adapter built into it, so that can mount Detour underneath your bike computer while still using the quick release function. Evo is a bit too heavy for the mount so we've only sent that to customers who specifically requested, but it's perfect for Detour.
We are anticipating we'll launch this in late May 2022 or Early June.
We are NOT doing a pre-order, nor wanting to do a big ole surprise drop like we did with Evo because we are pretty much out of the original Road Editions right now so we are fine with letting everyone know this is coming. Instead we have a signup list where you'll be emailed as soon as it's available for purchase.
Head over to the product page, read some more deets, and sign up to be notified when it launches!
www.outboundlighting.com
DETOUR
Detour Bike Light
Designed & assembled in the USA. Wide, perfectly even cutoff beam pattern that doesn't blinding oncoming riders, pedestrians or traffic while still being seen.
