41 - 60 of 756 Posts
Discussion starter · #41 ·
Just so im not leavin y'all hanging, i called the guy whos gonna make the shims the other day and left a message but havent heard back yet. Tomorrow morning im leaving for a 4 day camping trip out of cellphone range. so, hopefully ill talk to him when i get back and get these going.
Dwyooaj, Thanks, but Im ok. I have a couple of shims from an old old shock that I can probably play with.
Anyone know if there is a way to change the lockout? It's just not a feature I'll ever use unless it can be modified to be a diffrent compression/platform setting.
Yes. Mine is the medium compression setting (and is still too firm for my liking). What they changed to get there? No clue.
"You can make a soft lock out (still not descendable) , or make the lock out function a medium compression setting (descendable), or also adjusting the mid valve if you feel the fork dives to much in corners (also depends on your weight)"
That straight from xfusion? Any idea how to modify the lockout? I'd be interested in making it a medium compression setting.
Gotta give thanks where all can see,
I modified my slant by removing the entire shim stack, thanks to dwyooja's great clear photos on the disassembled fork, + my added 2.5 wt oil.
Went on a ride yesterday where the trail has rock gardens; sever breaking bumps; & steep drops as well, the fork works superbly for me compared to stock form, better than any fork I've used to date! Thanks again dwyooja for taking the time to get inside this fork & posting your findings & thoughts...
Kneecap, Good to know. Whats your weight, if you dont mind?
Discussion starter · #50 ·
I will be getting teh shims in a few days. they will be $6 each, or if you want 2 (d-bug) $10 for both. I know that sounds like a lot for a shim but such is the law of small batches. When I get them Ill contact y'all with my paypal. i want to make sure theyre perfect and flat first.
Discussion starter · #51 ·
Youre welcome. I agree teh fork feels much better with that shimstack removed. im still gonna try just oputting in the one, thinner shim, and see how that goes.
Discussion starter · #53 ·
I got the shims, If you want one paypal me $6 at jonesie29@gmail.com. These users are first in line and gauranteed to get one: grok22, d-bug (for 2), hokiebrett, ramjm_2000, and Kand. Anyone else, message or email me first just to make sure i didnt run out.
I put one in my sweep today (to reiterate, its to replace the stock .15mm thick face shim with a .1 mm shim, and I also put one of teh pivot shims between the face shim and teh secondary shim) feels like what I wanted to do , just a little firmer than with the whole stack removed. Will test on trail this weekend.
Discussion starter · #54 ·
Edit: its $6 if youre in the us. If youre elsewhere email or pm me your address and ill se how much extra international shipping is Thanks!
