Hello, I’m brand new to the forum so I apologize if this post doesn’t belong here.
Yesterday I picked up a transition patrol allow nx. First off this bike is so much fun to ride and as I lose weight it will be even better.
the rear shock is a fox float x oem model so it doesn’t have the low speed compression adjuster like the non oem model would have. I noticed that at 270 psi I still bottom this shock out and it seems soft even in the stiffer climb setting.
My question is would it help A. To get the shock tuned more for my weight? B. Is it possible to add a low speed compression adjuster in the air can? C. Would an air volume reducer help my situation?
Thanks for reading.
Thanks for reading.
