Hi there!
I have a bike with this evil rear axle size 9x141 QR (Boost). Which basically is a normal 12x148 BOOST Hub converted with adapters into a 9x141 QR.
My question is, I want to upgrade my wheels and a friend has a set of carbon wheels with a Novatec D791/2SB 12x148 Hub. After doing a huge research online, and being very close now to turn completely crazy about this topic...
Does anyone know if you can adapt a Novatec Hub into this weird size 9x141 QR??
Novatec has a complete conversion kit that you can use with most of their hubs (including the D791/2SB), but when it comes to QR, the conversion kit only mentions that it can be converted to a 9x135mm QR standard, nothing about converting it to a 9x141 QR.
If i am not wrong, a QR conversion kit reduces 3mm x 7mm the Hub axle size, making a 12x142 into a standard 9x135mm QR. (at least with other brands as DT-Swiss).
So If I do the same conversion with that same kit in the 12x148 Hub, I will be able to get this 9x141 QR size that I need, is this correct??
Has anyone made this? Or does anyone know something about Novatec Hubs and how can they convert?
This is the hub:
www.novatecusa.net
And this is the conversion kit:
a.aliexpress.com
Your help would be great for me, as I am no expert in this topic and there is not much information about this online.
This is the hub:
D792SB-B12-S4S-11S – Novatec 2021
13.95US $ 7% OFF|Adapter For Novatec 791/792 Hubs, Front Cap, Rear Axle For Novatec D791sb/d792sb,conversion Kit Replacement Fit Different Axles - Bicycle Hubs - AliExpress
Smarter Shopping, Better Living! Aliexpress.com
