From the pictures it looks like for a 2021 Orbea Oiz you should be able to take the integrated stem off and put a normal round steerer stem straight on. The shaped spacers are flat on top so the contact area between the stem and the spacer will be the same as if you had round spacers.I have a 21 Oiz M10 and I need to get a shorter stem. I was going to use something I had on hand, but upon looking at the spacers and headset cover It appears to be a whole system where I can't use normal round spacers and a normal 31.8 stem. Can anyone help me out on what I need to replace in order to use round spacers and a normal stem? Thanks!
It's an XC bike, not a trail bike. Even in 120 format.Hi.
I'm eyeing out a oiz m-pro TR for 2022 and thought I would ask fellow riders what you think of the bike (120/120mm susp.) in the trail discipline?
I get that you can't use it in Enduro stuff but how does it handle normal trails that are red, features like tabletops, drops, jumps, and such?
Also, what are the maximum width tires that you can fit rear and front?
Are they keeping the Oiz and the Oiz TR for 2022? If they keep the TR then I imagine the regular Oiz will stick with the 32SC. If they drop the TR and make the Oiz 120/120 like the Scott Spark then it will presumably get the 34SC.Is there any info about 2022 Oiz? I already ordered one for my wife but I don't even know what it looks like.
Frame is probably same - it should have better and lighter f34sc suspension.
I have put them on multiple Oiz, no problems.Somebody knows if the Stages left crankarm fits the Oiz (with XT m8120)? I've barely got place for the 10mm hex key like they recommand.
It might not answer your question, but my H10TR runs an XT crankset and I can only find one option for a 36T chainring, other than that it's all 32 and 34...Anyone know what is the biggest chainring both oval and round one can fit to a oiz?
I've tried searching but came up empty
Cancel your order and replace the factory dropper. I replaced mine with an SDG Tellis 170mm post a while back and love it.Best I buy me a better dropper with better service. Maybe Rockshox Reverb?
