381 - 400 of 577 Posts
I've been waiting a year for my SL-R (XL, Orange) and now that it's a few weeks away I have hit a snag. I'd ordered a Magura Thor Lift Select fork for the bike and the shipment arrived with a straight steerer instead of a tapered steerer. I'm also told that Magura have now stopped making the Thor lift Select so I can't even wait for one. I chose the Magura after seeing how straight forward they were to self service.
It seems my options are to put the straight steerer on or go with a different fork. I was thinking the RS revelation XX world cup dual position. It's a lot more money but lighter. Unfortunately it's not available in country (Indonesia) and will have to come from Singapore - with potentially more delays.
I'd appreciate any comments on either fork and the suitability of the straight steerer for the SL-R frame. I am determined to get a dual position fork but otherwise open to suggestions.
I remember the DP forks had a bit of problems earlier...make sure to check to see if Rockshox had fixed all the problems.
I've got a '11 Thor on my slr (to get the 20mm maxle, not 15). It's one of the nicest forks I have ridden. If you cant get a replacement with a tapered steerer I would suggest that you run the fork with an adapter.
Well,
I finally was able to take my SL-R home today. I'm so excited to get out and ride it now. It sucks I wasn't able to put all new components on it. I'll be upgrading the fork as soon as my frame sells. I'm also going to get a Crank Brothers Kronolog seatpost when they are released next month. The rest of the photos are on my page.
My build:
2012 Ibis Mojo SL-R (Medium, South Beach White)
Weight:
28.13 lbs
Bottom Bracket:
Shimano BB92 press fit HT2 adapter cups
Brakes:
Shimano XT disc brake, M-775
Cassette:
Shimano XT 11-34t, 9-Speed
Chain:
SRAM PC 971, 9 speed
Crankset:
Shimano XT FC-M770 Hollowtech 2, 44T/32/22
Fork:
Fox TALAS 32 R with QR 15 through axle system. Adjustable travel from 110 - 150mm with air spring pressure and rebound adjust with 7050 aluminum steerer
Front Derailleur:
Shimano Deore XT FD-M771 Down-Swing Front Derailleur Direct Mount 9-speed
Handlebar:
Ritchey WCS Rizer 20mm Rise 9D, O/S 31.8 x 660mm (Wet Red)
Handlebar Grips:
Troy Lee designs ODI lock on grips
(white)
Headset:
Chris King Devolution 1-1/"2 to
1-1/8", with 1-1/8" Devo plate (Red)
Pedals:
Shimano M520 SPD
Rear Derailleur:
Shimano Shadow XT, 9 speed long cage
Rear Shock:
Kashima coated Fox Float RP23 with adaptive logic boost valve technology
Saddle:
FIZIK Gobi XM with manganese rails
Seatpost:
Thomson Elite
Shifters:
Shimano XT M-775
Stem:
Ritchey WCS C260
100mm / 84D (Wet White)
Front Rotor:
Dirty Dog (bone burner), Front:203mm, Rear:160mm
Tires:
Front:
Schwalbe Big Betty, 26" x 2.4"
Rear:
Kenda Excavator, 26" x 2.35"
Water Bottle Cage:
King Cage Titanium
Wheelset:
Rims:
Stan's ZTR Flow 26" - 32 hole (White)
Front Hub:
Chris King Iso 15 mm through axle system (Red)
Rear Hub:
Chris King Iso 142 mm x 12 mm thru axle (Red)
Spokes:
DT Swiss Competition, 12 red and 20 white on each wheel
Well,
Nice ride. Universalcycles.com have some Kronologs in stock. They have one red/black 31.6mm.
Yeah, I planned on getting a 2012 Fox Talas 140 (White). Just found out my kid may have medical problems tho so I may have to redirect my bike money. I do plan on replacing it tho. I'm going to upgrade the brakes and drivetrain to xtr once I get the money. Took out today for the first time, rode like a dream. It's such a great bike, I'm glad I waited.
Unreal
Finally Finished:
Handlebar: 3T Extendo
Stem: Chromag 50mm
Seatpost: Thomson
Saddle: Chromag Moon
Frame: Ibis Mojo SLR Large
Fork: Fox 32 TALAS 150mm
Wheels: Easton Haven Carbon
Tires: Specialized S-works Ground Control
Crank: Shimano XT
Chainring: Rotor Q-ring 34 teeth
Rear derailleur: Sram XO
Chainguide: E*Thirteen XCX Direct Mount
Brakes: Shimano XTR Trail
Hope your kid is ok! You must of had the talas 150-110(110?) already, are you switching to 140 talas for the white? I was just wondering, I have the 140 float (white)ordered for my xl silver. The new talas 150-130 (I know black, ok for me also) I was thinking about for mine, was wondering how it rides or climbs? I have the 140-120-100 talas on my current bike and was trying to live without it prentending I had a float. Been standing allot in 3rd and that's works real good until I get into steep where it's loose and for sure ya have to be seated,,, that's where I use(1st gear) the talas!! I hear the float is a better performer, less to go wrong, ect. What have you found good for climbing??? I like the idea of a 150 out front. Maybe the new talas's handle better?
Well,
I finally was able to take my SL-R home today...
Nice looking bike. The wheels look great. I have the same rims, but those red King hubs and the red spokes really look nice. Mine SL-R's got a blue theme going on... but not at the hubs
Well done
Al
