Hey guys, Long time first time.
Love this shock, I'm a set and forget type guy and value for money you cant go past the CR, its light and has great upgrades/Mods you can do.
Recently i broke my bomber cr, bent the eyelet at the bottom of the shaft, This was my fault, mounting it the "Cool" incorrect way on my Norco range vlt, I had swapped this over from my enduro meta sx which doesn't do much now i have a ebike.
I noticed on avalanche suspension a small bracketed 230 x 75 shock mod, this always stuck with me and with wanting a park/shuttle bike, but not really wanting to spend the money for a dh, Doing the numbers it would give my meta sx roughy 192mm of rear travel, and make it the perfect shuttle/park bike which it pretty much is anyway.
So with a bit of the classic YOLO, I decided to figure it out, there is no made science about it, just some math.
I'll save the long story, you basically can use a 210 shock body with a 75mm shaft, this will give you a 230 x 75mm shock, or the way i have done it (and only because it was the cheapest 2nd hand pretty much brand new, close enough option) and to see if i wasn't crazy, a 225 x 75mm trunnion DH, This body was only 1.4mm longer over the 210 body.
With the help from a friend all we did was, just swap the shock eyelet body I.E the top part, i was able to convert it to a 231.4 x 75mm shock. close enough for me, and with having a flip chip, i just put it in low.
How did i figure it out ? I found the shock body's on silverfish, they had the measurements of each body. So even though i haven't done the 210 body 75mm shaft, but i would assume it will be safe.
How dose it feel? Feels great, i can run a lighter spring which will help make it feel more plush.
Next i want to get the fluid focus piston and see how much that will improves the shock.
