keen said:
Seems like the majority of posts concerning Manitou's SPV relate to the Minute series fork - any performance complaints w/ the Firefly? Under MTBR's product reviews the Firefly has many positive reviews none such that the minute receives as in these posts. Are Firefly's being ridden differently? I have an 05' Flick w/ the TPC dampner - always wondered if I am missing something not having SPV ?
God no. The TPC+ damper is much more sensitive and all around better performing than the SPV.
Many of the SPV sherman forks (04s obviously) have developed "clunks" in their travel. I've felt this myself on my friends slider and it felt pretty horrible this way. TPC+ is a great damping system, the only disadvantage is lack of lubrication compared to marzocchi forks, so make sure you have the semi-open bath seals and are running it that way, it should help. TPC+ has a floating compression piston, a compression piston, and a rebound piston, it works extremely well because it relies on the tried and true shimmed-valve setup, just like a marzocchi abiet in a different configuration (TPC).
What you get with SPV is low speed harshness and adjustable rate. This has been somewhat problamatic for manitou forks because they have traditionally tried to make their forks progressive by putting elastomers in them. The TPC+ was a little more progressive due to the floating piston which allowed for travel before the heavier damping of the 2nd piston kicked in, but I'd ride TPC+ long before I will an SPV fork.
TPC+ is/was good stuff, and there's more than a few people that are dissapointed that Manitou has removed it from their top forks.
