Question for the group here.... Here is the issue I have;
Fork = XLR 100 carbon
I am not getting full travel, lockout is not working and the fork is no longer plush in non-lockout mode. I had it serviced worked fine. Road it and it worked fine AT FIRST then gradually gets stiff/way less plush like it's kind of locked out. Had LBS (a great shop) service it again and re-bleed the lockout. That fixed it, until I went home, hung the bike on the ceiling upside down. I took it down today and its back to NOT plush at all feeling like it is semi-locked out. Also the lock does not work, it's like its stuck in the middle of lock out and float! I took the air out and cycled the shock same problem, reduced the air, same problem..... What do you think is going on, what needs to be replace?
