I bottom out my air Reba rl's at least twice every ride, usually more. Should I change something or is this normal? I've only rode the bike 6 times and it's a brand new stumpjumper comp ht. Thank!
In most cases, that's air pressure from the shock pump's hose escaping when disconnecting. When you attach it to check pressure, once the valve is depressed, air comes out of the fork to fill the hose (or space between the fork's air valve, and the check valve on the pump/gauge). The fork's valve will close when you unthread the pump or pull off the gauge, keeping air in. Basically, you don't lose pressure when you disconnect, instead pressure is lost when you attach something unpressurized to the valve and the air from the fork's air chamber fills it up to try and equalize the pressure (that's how your air pressure gauge gets its reading).Keep in mind that every time you disconnect the pump, you lose some air so the next time you hook up the pump it will read lower (about 5 psi, I think). I mention that because some people try to check their air pressure regularly and think they are losing air when they aren't.
I disagree. You do not want to "feel" it, any "firm" max travel "bottom" transfers a lot of stress to the frame and components (shock bolts, etc) that were not designed for it. This is even true when it doesn't "feel" like much force. Use the travel, but don't "feel" yourself using the travel=perfect. Most modern stuff should allow for a lot of ramp up in the last 10 and 5mm of travel, but if you hit bottom, increase pressure/preload and possibly spring weight.but firmly hitting the max travel every once in a while when you hit the most demanding features you encounter is not a bad thing.
I like this reasoning. I bumped up the pressure in my reba 10 psi. I prefer riding rigid anyway.In the moto world, you want to bottom the suspension on the largest or most abusive obstacle.
I have always run my suspension a little stiff on the bicycle. I never let my forks get (under normal riding) more than 90% of the way through the travel. Reason? Margin for error. In my mind, it works this way - if I get in trouble and slam something, I want that extra 10% normally unused travel to be there to help save me. If I am bottoming the suspension under normal riding, there is no extra travel there in the event of an off line excusion! Right, wrong, or indifferent, it's the way I've ridden.
Bottoming however is using full travel, sometimes with a bump at the end. You should never feel a SLAM, or feel a harsh stop. If you do, you need to stiffen the suspension. Increase your spring rate (air pressure).
