I just got a new frame and parts, trying to build my first bike, with no previous experience. I have seen/read that a lot of frames have these thin sleeves routed through the bike that you route your shifter cables through and then pull out once the cables are in place. My frame doesn't have this thin sleeve, but seems to have a large sleeve fully internal to the frame that you can't remove that will route the cable all the way through to the chainstay.
Do I route just the cable through? Or the whole housing? There are only holes for the entry, no grommets on either end. If I route just the cables, will I have to get some grommets to make it work?
Thanks,
Brandon
Thanks,
Brandon
