I swapped out a fork on my 2011 Specialized Hardrock. It has a stock Cane Creek (loose ball bearing) headset. Low-end stuff. I thought I had recorded where each part of the headset goes when I took the old fork out.
Regarding the upper headset, here's what I have install in this order:
1. upper cup (already pressed into headtube
2. ball bearings in retainer
3. upper race
4. plastic dust shield that fits into the upper race
5. plastic compression ring
I just finished installing the new fork and the last part I installed was the compression ring. But it doesn't look right. I'm seeing less than a mm of it sticking out and touching the headset spacer, which should sit flushed with the headset.
Am I supposed to put the compression ring AFTER the BB retainer, and THEN put the upper race and dust shield on?
3. upper race
