My new gravel bike comes stock with SRAM Apex shifter and RD. It's a Salsa Cutthroat, so can handle 29er wheels and tires. Naturally, I'd like to run my nice carbon 29er wheels with a 11-speed XD cassette in there for funsies. The problem is that the SRAM road group doesn't like working with SRAM mtb bits. Even if I completely back out the low-limit set screw, the derailleur can't shift into the 10T cog. And it'll try to shift twice on the 42T cog. So basically, it all seems to be exactly 1 gear off of what it's should be. When I put the stock wheel back on that has a 11-42 hyperglide cassette, I measure about 2mm different in the positions of the smallest cogs in relation to the seat stay.
The hub is a I9 torch MTB hub. I thought maybe I could swap out the freehub for a road XD freehub or maybe a hyerglide freehub and just go with a normal cassette. The I9 site says that their road freehubs are only compatible with their road hub shells, and same for their MTB freehubs, so I don't know if I'm going to spend $100 only to find out I have the same problem.
Has anyone here run into a similar problem?
It's not the end of the world if this doesn't work out. I think maybe the hubs would get annoying to listen to after a handful of hours on gravel roads.
Thanks.
EDIT: The current cassette is the XG-1195 X-Dome for X01. Would this be as simple as replacing it with a XG-1175 or XG-1150 which are marketed as XD cassettes for Force/Rival? Seems like it should be obvious, but now that XDR is a thing, I dunno.
Thanks.
