Available in Star Destroyer Grey and Bug Zapper Blue, the new Ripmo V2 has a one degree slacker head angle, improved lower link protection, updated dropper post cable routing, more progressive and coil compatible, and it's a smidge stiffer.
If you are running an ISCG05 bracket then you also need to run a 2mm spacer between the BB cup and ISCG bracket on the drive side. That should make everything line up perfectly. That's providing the BB is the same dimensionally as a SRAM DUB BB.I'm building up a Ripmo V2 frame with SRAM GXP cranks fitted to a Chris King bb. The chainring is 3mm offset (so what's recommend for 148mm boost hubs) and 32t. Ibis recommend that the ISCG05 bracket accounts for 2.5mm of spacers in the bb fit kit, so I've adjusted the spacers accordingly. However the chainring looks very close to the chainstay. What minimum clearance is safe? And what chain line is recommended?
Cheers
Yea well. I'm still procrastinating on the bottom ones though. I'll probably get around to it when the Jade X comes off for servicing.here to state this:
CLEARANCE THE BUSHINGS! Per OZIbis - who has recommended from soon after he got his and did it! They are so tight on the shock clevis. I had planned to do this weeks back and finally found some time. It really only takes about 25-30 mins but the difference in noticeable on the trail. You will be surprised how much smoother the travel initiation is and how much nicer this bike can ride.
This is an EZ fix anyone can do!!
Sorry it took so long OZ, Tan and others who have also done it.
All good it just matters that you did it. After getting in there you can see how a heap of load is getting transferred into shock shaft. I believe that's the reason why people are having issues scuffing the coating on the shafts. I know it's hard to bring yourself to do mods like this that are recommended because you are taking someones word for it that you don't even really know and making irreversible changes without replacing the bushes but it's SO worth it and I don't recommend things that I don't know for a fact are worthwhile and work without doing them myself first and testing the results.here to state this:
Dood stop being so cautious. It's not like the bike is stuffed even if you get it wrong, which you won't. You can replace the bushes for next to nothing. The bottom ones are SO tight as well. Like I said before mine had to be knocked out with a hammer and punch. You've got such an awesome bike get the thing dialled in and let it show its potential. Everyone is so wrapped up in playing with suspension and chasing plushness and trying different and progressive springs etc yet you will never get the best out of any suspension when the linkage is bound up and not working how it should. The poor rear end is so bound up it's like trying to play tennis in a straitjacket.Yea well. I'm still procrastinating on the bottom ones though. I'll probably get around to it when the Jade X comes off for servicing.
The top ones freaked me out when I realized how much material I was able to remove. But it's a lot smoother now for sure.
Ok ok!Dood stop being so cautious. It's not like the bike is stuffed even if you get it wrong, which you won't. You can replace the bushes for next to nothing. The bottom ones are SO tight as well. Like I said before mine had to be knocked out with a hammer one punch. You've got such an awesome bike get the thing dialled in and let it show its potential. Everyone is so wrapped up in playing with suspension and chasing plushness etc yet you will never get the best out of any suspension when the linkage is bound up and not working how it should.
That a boy. You won't regret it. Stop worrying there's plenty of materiel in the bottom bushes. They are much wider. You have to sand the bottom ones a lot more with more course paper initially. You would have a much bigger chance of stuffing the top ones and you did them without any issues.Ok ok!
And agree this is such an awesome bike. I keep getting PRs riding this bike in a local segment. Just when I don't think I can do any better… PR again! And I'm not even that good of a rider!
[emoji16]I'm as happy as a bird with my setup. I'm convinced doing the bottom link will no doubt further add to that sublime feeling. Gotta sync up with the Jade servicing soon.
How do you do this? What does it involve? I read back a few pages but there's not really any clear instructionhere to state this:
I ordered it as soon as it opened for pre-orders. Current ship ETA is July 7th, pushed back from the original June 29th date. I'll be sure to report back once it's tested! Caveat is that the test will be done with my Storia that's tuned for the link's spring curve (which currently feels all wrong on the stock link).Anyone ordered a Cascade link and tested it? Looking at the diagram it feels like the difference is mostly ramp up at the end of the stroke.
Yeah some extra mm would be nice. Curious about your impressions when you get it. Also running a StoriaI ordered it as soon as it opened for pre-orders. Current ship ETA is July 7th, pushed back from the original June 29th date. I'll be sure to report back once it's tested! Caveat is that the test will be done with my Storia that's tuned for the link's spring curve (which currently feels all wrong on the stock link).
A little bummed that it doesn't add any travel, but the increased progression will be real nice for coils.
I'm 5'7" and I'm on a medium, but it largely comes down to preference.5'6" riders - what size are you riding?
I don't know your specific answer but I have a V4 Ripley, HD5 and now a Mojo 4. A 32T chainring, especially an oval one, gets crazy close to the chainstay on all of them but I've had no issues because of it.I'm building up a Ripmo V2 frame with SRAM GXP cranks fitted to a Chris King bb. The chainring is 3mm offset (so what's recommend for 148mm boost hubs) and 32t. Ibis recommend that the ISCG05 bracket accounts for 2.5mm of spacers in the bb fit kit, so I've adjusted the spacers accordingly. However the chainring looks very close to the chainstay. What minimum clearance is safe? And what chain line is recommended?
Cheers
