Available in Star Destroyer Grey and Bug Zapper Blue, the new Ripmo V2 has a one degree slacker head angle, improved lower link protection, updated dropper post cable routing, more progressive and coil compatible, and it's a smidge stiffer.
What you are describing is a set up issue, not the component. What chain are you using and is is sized correctly? Is the cassette installed correctly/are the spacers correct between the cogs on the cassette? What about bb spacer(s)? Housing/cable installed correctly and not binding? High/low/b settings? These are just a few things, but a shop should know this.thanks for replying, yeah, it seems to constantly require tweaking, I'm not riding on DH trails with huge jumps, just your average technical trails, it seems like after taking it in, getting it tweaked back to not skipping/jumping/grinding sounds, i go for 2-3 rides and then its back (either it skips on the middle cogs, or makes grinding feeling/sounds).i make sure to turn on the clutch when i ride, and turn it off when its back in the garage. Yeah, this bike is not a newbie friendly bike at all, but i suppose the silver lining is I'm learning a ton about the components, unfortunately its time i'd rather spend doing other things.
yeah, probably, i wouldn't know, again im a newbie and i ordered this bike from an ibis online dealer since there aren't any local ibis selling shops nearby. There really should be a "check list" or a to do list when bikes arrive to customers, i don't think ill order online again. Just venting, and hopefully giving warning to other newbies thinking about purchasing a hi end bike thru online dealers.What you are describing is a set up issue, not the component. What chain are you using and is is sized correctly? Is the cassette installed correctly/are the spacers correct between the cogs on the cassette? What about bb spacer(s)? Housing/cable installed correctly and not binding? High/low/b settings? These are just a few things, but a shop should know this.
Curious, did you reach out to the online dealer? What was their response?yeah, probably, i wouldn't know, again im a newbie and i ordered this bike from an ibis online dealer since there aren't any local ibis selling shops nearby. There really should be a "check list" or a to do list when bikes arrive to customers, i don't think ill order online again. Just venting, and hopefully giving warning to other newbies thinking about purchasing a hi end bike thru online dealers.
haha holy crxp, that's no bueno at all... no ive contacted the dealer and their response was "take it in to local shop".... yeah i feel like i should maybe have it rebuilt like u did, probably find a few other things i wouldn't know to check forCurious, did you reach out to the online dealer? What was their response?
Regardless of one's knowledge, it's good to reach out. There may be one person out there with a similar experience that can help address your issues.
As for buying online, it may be a crapshoot. It boils down to experienced mechanics and/or those who care about what they are doing. I just bought a bike from a reputable dealer and the build was sub par. I tore the entire bike down and re-built swapping parts and this is what I found: the hanger was not properly installed, rd limits were not set, brake hoses were trimmed which should not have been done until the bike was sold and fitted, brakes needed bled, bars were not square to the fork, stem bolts not properly installed and bolts not torqued for the front brake rotor. I let both Ibis and the dealer know.
Best of luck.
Yes, a shop in Santa Cruz had 2 larges a few weeks ago. I bought one.Anyone having any luck with finding a Ripmo in a timely fashion? Hard to believe they are 1/2 year out...for a bike?!?!
Sent from my iPhone using Tapatalk Pro
Give Shaun at N+1 bikes in KY a call He is the man!Anyone having any luck with finding a Ripmo in a timely fashion? Hard to believe they are 1/2 year out...for a bike?!?!
I had an XL Ripley LS with 70mm stem 800mm bars and now ride an XL Ripmo with 45mm stem and same bars.Ok, so it seems demos aren't out and I'm not sure what size I'd be in case I can find one online? I'm 6'1" and have an XL 2017 Ripley LS. No way a large Ripley would of fit me that model and year anyways)
That said, I haven't ridden the new geo bikes with longer reach etc. the old ibis's seemed to run small...you think I'd still need xl ripmo or would a large ripmo work?
I am 6'1'' and ride a size large V2 with a 50mm/0 degree stem. Sitting in the saddle this almost feels short, but the fit feels spot on when riding. I may adjust the stem spacers and swap to a 60mm stem for a comparison. Obviously, when it comes to cross over sizes it boils down to personal preference and the terrain you ride.I had an XL Ripley LS with 70mm stem 800mm bars and now ride an XL Ripmo with 45mm stem and same bars.
Sent from my SM-N950U using Tapatalk
I am 6.1 on an XL coming from an XL HD3. Perfect fit with a 55 mm stem.Ok, so it seems demos aren't out and I'm not sure what size I'd be in case I can find one online? I'm 6'1" and have an XL 2017 Ripley LS. No way a large Ripley would of fit me that model and year anyways)
I'm using an EXT Storia V3. I'm 160lb and using a 425lb spring. I originally started with an AF. It had a DVO Topaz T3 in it. I had that shock set up pretty well and it was a pretty good little shock. The AF also had a DVO Diamond in it. In some ways I thought the Topaz outgunned the Diamond once they were both fully dialled in. I upgraded the Diamond to a Manitou Mezzer Pro. This caused the Topaz to be seriously outgunned. So then I upgraded it to the EXT, with a 450lb spring with 1 turn of preload to get 30% sag.I would like to hear from people that are using coil in their ripmo V2, which brand, which coil and why did you do the switch?
Cane Creek will definitely be cheaper for sure. As far as tunability goes the EXT is VERY tuneable. PLUS and it's a big plus you get a hydraulic bottom out bumper. No more "feeling" like you are using all the travel all the time with a sudden rude stop or knocking noise from the rear end. You still are but it doesn't feel like it because it's so supportive and progressive at the end of the stroke.ozibis - once again "splaining" the goodness of good suspension bits. Your point about the rear end causing the Ripmo to "decelerate" in repeated choppy/square edge bits - spot on. My suspension guy coined it a "hitchy" feeling - like it starts to tug at the rear and indeed slow down. I've felt it and its the only knock I have on the Ripmo. It was the reason I sold my previous bike which is a very similar rear suspension design. Now you go and make me not only want to buy the V2 (for other reasons you've described in the AF forum) but a new coil as well. And here I was just gonna replace the Ripmo w something "else"... I gotta check in on a EXT in the USA... I was thinking about the Cane Creek IL Coil... it likely cheaper but, but I know some like it on this bike these days as well as its light and tunable
Always appreciate your perspective and ability to describe the "feel" - rock on mate!
I'm currently on a V2 Ripmo with a Push ElevenSix. This shock is beautifully made and very adjustable, but to be honest, I'm not sure this shock suits our frames well based on my recent experience. I've had this shock on a few horst-link bikes (Transition Patrol) and felt like it was much more impressive than it is on my Ripmo. I was expecting that traction-rich ride that I've had from other Push applications, and I'm just not there yet and it feels overdamped even when backing out HSC/LSC. I'm hoping Push can help me dial things in.I would like to hear from people that are using coil in their ripmo V2, which brand, which coil and why did you do the switch?
