I'm going to be building my first carbon wheel, and I've been reading that carbon rims have thicker rim beds therefore they may require longer nipples? Does anyone know what length nipples Ibis uses?
Thanks.
Thanks.
Thanks for that, ckspeed! I've got the washers in hand.If you use the washer, I think it's best to go with 14 mm nipple length.
Wow! Ibis uses alloy nipples? I wonder if that is the primary reason they use nipple washers?We use these nipples:
Sapim Double Square Alloy Nipples (Black), 14g/16mm
1) I'm not sure why different hubs would necessitate a different nipple length.We use a 16mm nipple in our Industry Nine/Ibis Rim builds, and a 14mm nipple in our Ibis Logo Wheel/Ibis Rim builds.
I ended up building my rear 742 wheel with high strength 14mm aluminum nipples from wheelbuilingparts.com
Unfortunately, 3 months later I'm experiencing this:
The spoke is fine, it's the nipple that cracked.
I used one wrap of Kapton tape, and the tape held up fine, there was no leaking sealant. This is the second drive side spoke that malfunctioned in the past two weeks.
No corrosion. Clean break.Is there any corrosion on it or does it look like a clean fresh break?
I used a Park tensionometer while building. My Onyx rear hub has a max 120 kgf, so I built to that tension. I don't recheck tensions after a few rides because mounting a tire reduces the tension. I did recheck tensions after the first nipple broke because I had to take the tire off to dig out the broken nipple, and I had to re-tightend all the spokes to get back to 120 kgf. I do plenty of stress relief by squeezing parallel spokes when building, so I was surprised that I needed to retighten all the spokes.Did you use a tensiometer during the build and recheck a few good rides later?
I follow Roger Musson's wheel building book, and although he mentions that method of stressing a wheel, he says he doesn't use it--instead he squeezes parallel spokes. I'm certainly not an expert wheel builder: this was only my 7th wheel that I've built and my first carbon wheel. In any case, I never hear any pinging of spokes when I ride my new wheels for the first time, so I think they are properly stress relieved. On the other hand, my spokes did seem to loosen on my latest build.Linked to a video showing how to do it basically, but I put it on the floor on a mat, then apply all my body weight on opposite sides of the wheel, I rotate the wheel 8 times hitting all parallel spokes.
Yeah, I checked the drilling very carefully. I'm pretty certain I laced the wheels correctly. There's one way to find out: can someone look at their rear 742 wheel, then look at the first spoke to the left of the valve stem and tell me which side of the hub that spoke goes to? The drive side or the non-drive side? Secondly, is the elbow of the spoke on the inside of the hub flange or the outside? Thanks.One other thing, not certain of those rims, but some are actually directionally drilled, so if you lace it wrong, the angle the spokes come out of the rim will be worse than if it was a regular drilled rim and you will experience what you're thinking of.
In that case, wouldn't the nipple crack right at the end of the spoke (or above the end of the spoke)?If the spoke didn't break then they look like they are too short.
