I am sure that this question has been ask many time, but I want more advise.
I am using Avid V-Brake with Avid SD7 levers,I want to upgrade to disk brake.
I am not good in mechanical (except when it come to adjust v-brake), so, when it come to install hydraulic disk brake, I am not sure that I will be able to do it (like cuttin cable, make the blend, etc).
Actually I am looking to:
If I go with hydraulic, the problem will be choosing the levers. Can I use any hydraulic levers with any hydraulic caliper? The other problem will be installing (cutting the housing).
What are your suggestion? If I should go with hydraulic, what are your suggestion? I got a 200$ budget (I already have the wheels: Mavic x317 disk with Shimano Deore hub and Shimano rotor).
- Using Avid BB7 caliper with Avid SD7 levers (one of my friends gave me two Avid BB7 caliper, one road and one MTB).
- Go with TRP Spyke caliper with Avid SD7 levers
- Go with hydraulic brake system
