Hub grease questions
10K views 38 replies 21 participants last post by  TylerVernon
#1 ·
this is the spare hub I checked.
Hello!
Stripped down my rear hub and freehub today on my bike, replaced all the bearings so happy days!
Unfortunately after putting everything back together the hub no longer clicks, I’m sure this is down to either using far much motorex 2000 or motorex being far to sticky to use on the pawls area.
I purchased another hub to mess around with and checked it out tonight, its almost like vaseline… any idea what it is?
Any thoughts on where I’m going wrong?
What grease would you recommend.
Thanks in advance
#9 ·
I use motrex for the bearings, and dumonde (either grease, or the oil depending) for the pawls.
btw, your example hub looks more like hub grease.. whiteish.. it's probably not sticky, is it?
  • Like
Reactions: CocoPlops
#14 ·
I never use freehub specific grease other than for an onyx. I like to shut hubs up with something heavier. I'll bet after just a ride or two the noise will come back. In my experience you can't shut hubs up for long with lubrication. As long as the grease isn't so heavy the springs gunk up you're good. It doesn't look like the grease is too heavy to me. T
The bike industry loves to market specific greases but few parts actually need specialty grease. I'm running the blue grease that came with a Santa Cruz bike in a dt 240 54t. Runs quieter and just as efficiently as the factory dt Swiss free hub grease it came with. I also ran slick honey but it was louder. I've even run marine grease with no issues. I was conservative with the marine grease. You could probably gunk up the pawl springs if you packed it on too heavy.
#16 ·
I use Mobil XHP 222 for most of the year. It's really thick and tacky but it lasts. It's what Hope spec in their hubs (I have a Pro4) and those are plenty loud. You only need a small amount on the pawls and then just enough to form a barrier around any seals. You won't break anything by using too much but it will mute the hub a bit for a few rides.
Mobil Polyrex EM is thinner and less tacky. I use that in my Halo Supadrive. Neither grease comes in a fancy package and they don't smell like raspberry tart or peppermint, but you get a big grease gun tube of them for less than a tenner and they last for ages.
I sometimes use Slickoleum in the summer. I don't know that I can feel less drag but it makes the hub louder - useful for letting walkers and wildlife know you're coming.
#21 ·
WRT riding in a wet area. Dumond or not if water gets into pawls then the grease will emulsify into a grey froth of water and oil, and it will stop acting like grease, and the innards will rust.
You’ve got lots too much grease in there, and it looks a bit thick.
  • Like
Reactions: Mac_89
#27 ·
Wow, this thread is all over the place! Some good advice. Some great suggestions. And some ill-advised.
Back in the day, Phil Wood sold its "freewheel grease injection" tool so you could simply PACK a freewheel full of grease after flushing out the old lube & grit. It was really cool, your freewheel ran SILENT!
But then freewheels started showing a propensity for blowing up. The pawls cannot properly seat when packed with grease. Under high loads or sudden immediate engagement on a steep climb and "BAM!" Shimano wouldn't warranty any freewheel that was greased. Let that freewheel and grease pick up some grit & grime and you're really set up for problems. Shimano specifically advised against using the Phil Wood tool. Light oil is what most pawl freewheels and freehubs require. Anyone using grease needs to understand that they may be reducing the freehub's life and durability. When a pawl isn't fully engaged, it may slip. Slipping causes chipped teeth & engagement ramps and damaged pawl seats as well.
Since pawl springs are as variable as tire choice, it's best to simply follow the manufacturer's recommendation on what lube to use with your pawls, springs and engagement ring. Using grease of high viscosity when light oil is called for is simply playing with fire.
DT specifies their grease for their star ratchets. Given their history of sudden failure, and some QA/QC problems with surface hardening/heat treating,* I think it's worth the extra cost of one of their little containers of pink grease. Should last the average consumer 5-10 years.
King specifies their RingDrive lubrication for their hubs' killer ratcheting system. $600 rear hub alone and you're gonna "pick what you think is best?" Not the brightest idea if you ask me.
But in general, if you cannot determine the ideal lubrication for a freehub's engagement system, light oil is almost always the best bet. Yes, it will be louder than if greased. So try something else if you want more silent freewheeling. Feel free to experiment! Have fun! But don't you DARE mention the word "warranty" if things go south. No complaining on the internet about "XYZ's shitty hub blew up while I was 20 miles from the trailhead!" if you're gonna stray from what the manufacturer suggests.
*https://www.sciencedirect.com/science/article/abs/pii/S135063071300109X?via=ihub
#28 ·
+1 on this.
#33 ·
I use whatever lubricant the manufacturer recommends for servicing hubs and apply a thin layer where and as directed unless otherwise specified. Don't particularly care how loud or quiet they end up though they are generally quieter for some period of time.
Rarely if ever have I dunked front or rear hubs in water crossings and haven't observed any water inundation in them.
Definitely submerge BB's occasionally (especially with the newer lower ones on many frame designs these days).
#35 ·
So what gives? You guys immerse bearings in water and no problem!?!
I never immerse bearings in water but I do ride all winter in the pnw. Sometimes the trail is a creek of running water 3” deep. It’s very very wet and muddy.
I have had a lot of trouble with rusted bearings. A hope and a legacy i9 freehub we’re the worst, they’d have water inside after a single ride and if not cleaned out the grease would fail and hub would lock up. The seals were just not good.
Older cup and cone shimano stuff lasted pretty well for me, and I’d drizzle oil into the freehub after wet rides. the fix for my modern gear was Chris king. I service the hub when it gets noisy, usually that’s every spring, it needs it but not a catastrophe like I would get with that i9.
  • Like
Reactions: bcharv and Mac_89
#36 ·
Hello!
Thanks in advance
I use a very thin coat of sram butter. I don't like packing grease in to the pawls. It can cause it to stick in extreme cases plus I like loud hubs. I service frequently too, so it's never dirty or dry in there.
