161 - 180 of 741 Posts
Its down on travel currently (as expected), so not 100% done. I used a tora coil u-turn spring. Just have to change the lower leg cap from a seal head to one for a coil. I used the drake lower cap, and a drake top spring cap. Removed the u-turn cap (its just a c-clip), drilled out the drake cap and installed a short rubber bumper and put the c-clip back on. Slips right in and you're on your way! If i had a pike spring, it would be perfect.
I intended on using all manitou parts for a coil conversion, but they just dont exist. Tried a drake coil pushrod, but its too narrow and falls through the lowers. nixon 145 coil, but its way too long and too fat. The RS u-turn parts end up working better.
Weight be damned, im faster on the coil and its so so much smoother!
Discussion starter · #165 ·
That is awesome. Post some pics when your done. I love franken forks. A straight coil Minute is very appealing.
Help with ABS+ installation
Hey all, slightly off topic but I just installed the ABS+ damper in my 2007 R7 super 100 TPC. Everything went fine until I tried to tighten the compression rod fixing bolt to the suggested 45-55 inch lbs....the bolt just keeps turning and I can't get it tight enough. I guess the compression rod is spinning around inside the leg? Any guidance? Thanks!
Try adding air to the air spring then finish tightening the bolt. Might just need a little resistance to finish it off.
You'd have to have some serious balls to impact that on! Thats asking for a disaster.
Get it as tight as you can get it, lock out the compression and go bounce down the street for 5 minutes. It'll seat, and tighten up afterwards.
Fixed, thanks
Thanks guys, I just rode it around for a few minutes and was then able to tighten it up to the correct torque. Good suggestion One Pivot. It's not that big of a deal to take it apart again and clean the threads, but I was glad I did not have to go to that effort again.
Obviously I haven't gone on any real rides yet, but the new damper seems to be doing what it claims...more plush in the first 2 inches of travel and more stiff upon deeper compression. Hopefully this will limit the substantial brake dive I experienced with the original damper.
I have just got the ABS+ damper to replace the 2008 absolute one
But I'm confused about the oil
for my 130mm MRD The manitou service manual says 125mm, but in the instructions that comes with the new damper says 110mm
may be ABS+ needs less oil?
which is the correct one?
thanks
Discussion starter · #178 ·
thanks
I would go with what the instructions for the new damper says. If the oil level is to low you will know, But I think the ABS+ damper is slightly longer allowing for the lower oil level.
Thanks,
I will mount it this week
And I'm planning a tunned remote instead of milo, to be able to select 3 potitions: open, low platform and lock, that are what me (and most) use
I will post it her if it works
