341 - 360 of 741 Posts
I've got a 120 Tower Pro on a SB95. I'm mainly been posting my tuning on the "Tuning a Tower Pro" thread. I have tried a few different stacks, mostly trail and linear, but have been playing with a 2 stage here lately. I didn't really care fore the trail stacks as I have no need for any platform whatsoever.
current 2 stage:
17x.15
13x.1
17x.2
17x.2
Both stages are too soft and it developed an audible click when transitioning from comp to reb. Ultra plush, but it blows through the stroke pretty badly on any type of high speed hit. I believe it is the face shim causing the noise as it get worst as the lsc approaches fully closed. First I'm going to go back to a straight stack and see if the noise goes away. Then, I will play with the 2 stage some more, adding stiffness to both stages.
I also recently tore apart the rebound piston. The rebound stack is a single 21x10x0.3 shim. I plan on lightening the reb stack at some point. There also appears to be plenty of room to install a midvalve, which I'd like to play with at some point, but that's far off. Too busy playing with shocks right now.
No, the 130 is fixed travel. The 100 is adjustable down to 80 internally. Almost all the Manitou "Expert" and "comp" models do that.
Looking at the Manitou '12 Service Manual there are 5 parts that are associated with the 130mm travel option. If these five parts replaced the like parts of the 100/80mm travel option, would this effectively make a 130mm travel fork?
Also seeking some advise; I just ordered the Circus Expert 80/100mm. My primary use I intend for the fork is Urban Assault, with some XC and light AM thrown in. I weigh low 170's without gear and don't fluctuate personal weight much at all.
Everything here is a climb. All of the good parks in town are large hills that you have to ascend in order to use. The places I go don't have much for rock/root gardens, just occasional obstacles, but there are lots of drops and jumps. When I do get out for some trail riding, I'm not looking to kill the bike the fork is going on, so the trails this bike will see will not be all that fun for a FS with 120mm+ of rear suspension. However, the trails it will visit wont be smoothed out. I'm going to be jumping up onto obstacles too, so I wouldn't want the fork to extend to quickly messing with my balance.
Were would be a good place for me to start, I was thinking the Trail series, or that maybe Linear would be more the thing for Urban assault; what do you guys have to say?
Edit: Spelling
pdxmark,
one of these parts should be the longer stanchioned CSU, which costs comparably to a whole fork.. otherwise yes, you can build your own fork from Manitou parts.
As for the damper tune, I'd look for a very light platform and a minimal speed stack initially. For urban, run it with platform and see if you need more speed shims. For offroad you can open LSC a bit (though I don't do that on mine because I mostly stand, thus it's quick to bunnyhop/unweight over most stuff, but I always need the platform).
Called Manitou about the 130mm upper stanchions, Manitou only makes the Circus 130mm in Tapered.
So...
Edit: Deleted: forget all that. Was emailed a coupon for 25% off items over $200 at PP. So what did I do... Picked up the 2013 Minute Pro for $210; and, it has no frame to go on right now!
Just got my Circus Expert in the mail today, and ordered another fork :yesnod:
Edit2: Where can I get a medium spring for the Manitou CE?
Kind of OT: I'm getting a Samurai with a 44mm x 114mm headtube, I would like to use the 'Cane Creek AngleSet Headset' so I can play around with the angle of the fork.--Deleted irrelevant sentence--.
Ok, thanks.
I checked offer MX-Tech and RSP- i can't find shim OD 17,5mm. If i use shim OD17mm or 18mm what is change in curves? i think about:
CV-11311-01 Production “Trail Stack”
11 x 0.5t x (1)
19 x 0.2t x (2)
17.5 x 0.2 x (1)
or
CV-11411-12 Linear
13 x 1.1t x (1)
13 x 0.1t x (1)
17.5 x 0.20t x (3)
