How much difference does an XC tire make in the pedally bits? Anecdotal data inside.
1 reading
7.5K views 41 replies 26 participants last post by  jimPacNW
#1 ·
I built up a Canfield EPO hard tail but didn't have a rear wheel to use since it was non boost. I borrowed a wheel from a friend to use until a wheel I ordered arrived. It came with a Maxxis Assegai on it (29x2.5 3C Max Terra). I have a test lap that I run at lunch at my local trail. It's a 8.14 mile selection of trails I made into a long strava segment. Sometimes I run to at race pace to a feel of where my equipment and body are at. PB is around 47minutes on my Kona Hei Hei. 49 minutes on my single speed. I ran it in 51:27 on the Canfield.
Two days later my wheel arrives. I set it up with a Rekon Race 29x2.35 120tpi EXO. Disappointing as far as weight over 850g so only about 200g lighter than the Assegai on my scale. Wheel was a little heavier so really only list about 120g total when it was all said and done. On 48 hours of recovery ran the same course at race pace with the same warmup before running the course
. Ran a 50:19 with an asterisk as I stopped 25 seconds to tie a shoe that came untied, another 30 seconds to give someone direction, and ran into slower traffic twice while the 51:27 with the assegai was a clean run. Average heart rate in both runs was 162bpm.
So in a ~50 minute ride at race pace going from an enduro tire in the rear to an XC race tire with no other changes made a ~2 minute difference.
EPO with Forkaster V2 front and Rekon Race rear tire setup.
#2 ·
I've had similar results though never done a "scientific" test. I have a couple of wheelsets with different tires that I use for different conditions. The faster tires usually reward me with -1:30 to -2:00 minute times (sometimes a little more) on a 23 to 24 minute lap of technical but rather flat xc singletrack.
This is not at race pace however, just good fast fun riding pace.
I suppose the results may tighten up if I were to give it an all out effort on the "slow" tires. I believe the gap may tighten because of the traction limitations of the "fast" tires.
I may have to try this...
#8 ·
Can easily be 5-10%
#9 ·
A fast rolling XC tire can easily cut several minutes off a 50 minute ride, but I would expect more honestly. That 8.14 miles in 51:27 is like 9.5 mph and in 49:24 is like 9.9 mph. Although I guess it depends pretty significantly on the trail, IE a lot of stop and go type tech and corner braking before climbs can drop average speeds pretty dramatically.
#17 ·
Lots of navigating rock features at (relativly) slow speed, lots of turns and braking. Constantly accelerating out of corners or features. The KoM averaged 12.0mph. My PR s 10.4mph. This long segment is comprised of 9 smaller segments. Of these 9 segments only 3 have parts where I run out of gearing and spin out on my single speed. I spin out around 14mph on the single speed.
#12 ·
Wow, that's almost as much as an advantage as trading in an obsolete 27.5 bike for a shiny new 29er.
Funny...my 29er is quite a bit slower (10-15%) than the 27.5 with the exact same rear tires and similar fronts. The 29er is 2 years newer, too. Wheel size is still not the end all, be all when it comes to what makes a bike perform...but keep following the marketing if you like.
I love my 27.5 bikes. Why? Because I own them. I shall defend their honor until they are sold.
I still pick the 27.5 8 out of 10 times because they're more agile and fun to ride.
...anecdotally, of course. ;)
#14 ·
I've had similar experiences with Specialized Fast Trak (up front) and Specialized Renegade (on rear) versus either a Maxxis Ardent Race or Recon. The Specialized tires will improve my speed a solid 10%+. However, they are extremely light and very prone to side wall wear/failure on my local trails.
The Fast Trak/Renegade is my go-to on race day but definitely not a durable tire combo for other rides.
#31 ·
Compound must be taken into consideration as well. The softer the compound, the slower the tire.
XC tires make a huge difference in flatter, more pedally terrain. However, there is a law of diminishing returns. I’ve done a lot of testing on one of our downhill trails (I’d rate it a blue trail). It’s got some steepish bits occasionally but overall you’ve got to pedal and pump quite a bit to stay fast.
I’m always chasing my PR on this trail, and since it’s easy for me, I’ve tried running XCish tires in hopes that I’d gain a lot of speed on the smooth pedally sections. All in all, I am consistently faster on the lower half, but slower on the upper half, because the XC tires are…scary, and I can’t trust them to hold in the corners.
My best overall time on the whole trail is with enduro class tires, on a hardtail.
In true XC conditions, a proper XC tire set can’t be beat.
#34 ·
I commute into work on a rural highway, but even driving 65 mph, I’ll get passed by folks who want to drive faster.
I’ve noticed that those same cars that pass me are often no further down the road once we get into town and there’s more traffic.
I haven’t checked their tires, but I don’t think that’s the reason they are slower in traffic.
#38 ·
@OP, that's a significant time difference, although I would expect more for different tread designs and weights.
How about perceived effort? Did the faster tyres feel they rewarded your effort more?
I'm usually on DH treads on enduro casings (1000-1200gr) and after reaching a certain speed it feels like there's no point pushing any harder. Not much gain for the extra effort, at least that's how it feels, but strava tends to confirm this.
#40 ·
Some of the results from those rolling resistance tests are surprising. Conti Race King XC Protection has half the rolling resistance of a Pirelli Scorpion XC Lite, weight within a few grams of each other, visually similar central tread, the Continental has taller blocks by 0.5mm, but the Continental has a 1.75mm measured center casing thickness to the Pirelli's 2.00mm. I'm not a paying member of that site, but the devil is definitely in the details.
Not to prattle on and nerd-out on this, but it's the same argument for aero for the average enthusiast vs. pros--it seems to not matter because we all go slower in comparison, but we also take longer to cover the same distance as the pros making it actually more beneficial on the clock even if we can't physically perceive anything as we ride.
