Thought I'd resurrect this discussion about Handlebar height which is one of the things I've been working on over the last 20 years. Here are my thoughts on that and please share your own experience:
I learned quite a bit while training and racing last year, and would like to share an
IMPORTANT BIKE SETUP CONCEPT with you that greatly impacts how you ride.
Precise handlebar height is more important than I realized! I made a small handlebar height adjustment and it ended up sabotaging my racing and riding for 6 weeks. Many of my students' handlebars are too high and often
we lower them 10-50mm, to get them in a better, more confident position.
Often, bikes come from the shop in the most comfortable position with 20-50mm of spacers under the stem and riser bars (bars that ride 15 to 40mm higher than the stem).
This feels good in the parking lot and while seated and pedaling on mellow terrain, but when you want to ride more demanding trails, it can get in the way.
In my courses, I explain that if your bars are too high it makes riding more difficult.
When climbing with your handlebars too high, it is hard to hinge forward enough to keep the front wheel on the ground on steep climbs, even when you have slid your weight all the way forward on the saddle.
With high handlebars, wheelies and manuals are harder to do and tend to put you in a
"hanging off the handlebars" body position with your weight too far back while descending.
The goal of finding the right handlebar height is to find a height that puts you in an athletic, centered, neutral, and hinged body position when standing and descending while not compromising your climbing body position.
Aaron Gwin in a hinged-at-the-hips-flat-back riding position )
Reaching this goal has become a challenge as our wheels get bigger and our forks get taller with more suspension travel. For people approximately 5'6" and shorter, it was much easier to get the bar height right on a 26" wheeled bike with 75mm of suspension travel than a 29er with 130-170mm of travel.
Before we get further with bar height,
LET ME EXPLAIN AN IMPORTANT RIDING CONCEPT:
Riding confidently and on the offense (riding with a focus on accomplishing what you
WANT to do instead of focusing on what you
DON'T WANT to do) is one of the most important aspects of mountain biking.
Focusing on getting to the bottom of the descent
smoothly or quickly instead of focusing on not crashing, is paramount to riding at your best.
It turns out that
HANDLE HEIGHT affects more than just your body position!
A mere 16mm rise in bar height (that I thought was going to take the stress off my shoulders and allow me to look further ahead) not only hurt my position (as I teach) but it killed my confidence.
• That 16mm rise put me in the "hanging off the back of your bike" position. In my courses,
I teach that too-high handlebars make it harder to stay centered while descending.
• If you think about it, that is a very
defensive posture; leaning back away from danger.
• It is also more upright than being hinged forward at the hips with a flat back.
Being upright decreases our stability and our ability to stay neutral (where we can react/respond better to what the trail throws at use.
Check out my
"Body position and Fundamental Movement Video Tutorial"
Well, that defensive posture put me on the defensive and I spent the week of the National Championships riding scared (I managed to win but was disappointed in my nervous riding). Let me tell you
this is a vicious cycle!
Start riding on the defensive and you start making mistakes. Those mistakes scare you so you feel like you can't ride well - further shaking your confidence.
Of course, I attributed this to a crash I had three weeks before, not to the seemingly insignificant change in bar height. This did feel a little weird right away,
but change always feels weird so I just thought I would get used to it.
After racing the National Championships and then another regional race, I was really frustrated with how I was riding (despite winning my class).
BUT THEN I realized my handlebar height might be the culprit
so I lowered the bars 10mm by removing two headset spacers under the stem.
(My handlebars in the photo below).
The difference in confidence was immediate! With the first run with lower bars, I was riding much more aggressively.
Until this experiment, it would have been hard for me to believe 10mm in bar height could make that much of a difference but, it did!
It forced me to hinge a little more and more importantly: it centered me over the bike in a much more stable and aggressive position.
I often tell students that their handlebars are too high when they are obviously 20-60mm too high,
but now I know I need to stress experimenting with bar height more for all my students. If 10mm can make a huge difference in body position, confidence and control imagine what 15-60mm could do.
All of that contributes to putting us in an upright and slightly back of center position: not quite in balance, not neutral, and ultimately a defensive position.
IN SHORT - experiment with your handlebar height. Go as low as you can go with your current bars.
Many riders (those under 5'10 riding 29ers and under 5'8″ on 27.5 bikes) should try a bar with no rise.
Your handlebar height should help you achieve the hinged-at-the-hips-flat-back riding position like Amaury Pierron pictured below.
I wish there was a simple formula for bar height. For me, it is when my bars are about 3″ above my knee when standing and coasting with pedals level.
For shorter people, it can be as high as their belly button when they are standing on the pedals.
Again, the goal is to have your bars low enough for climbing and to put you in an athletic, hinged at the hips position when standing and descending.
Too low and it may hurt your back and make it hard to look ahead.
Too high and you may struggle with keeping your front wheel on the ground during steep climbs and/or find yourself hanging off the back of your bike while descending.
The old rule of thumb that your handlebars should be level with your seat (at full climbing height) to 3 inches below your seat (at full climbing height) is a great place to start. In general, the taller you are the more drop from seat-height to bar-height you will have.
At 6'3" my bars are about 2.5" lower than my seat. Many riders who are under 5'6" will find it hard to even get the handlebars level with the seat on a 29r. Pro XC racer,
Chloe Woodruff who at 5'2", runs a
negative rise stem to get her bars lower (as do many riders under 5'6", especially if they ride 29er's).
Many/most mountain bikes are sold with the handlebars as high as the steerer tube will allow. This is usually the most comfortable position for seated riding (allows a straighter back, less hinging at the hips) and it leaves four or five 5mm spacers under the stem.
This gives you 20-25mm of adjustment.
Often, I suggest a student
remove all the spacers from below their stem and put them on top (lowering their bars 20-50mm) and they love it.
All of my bike setup suggestions are based on performance, not comfort! Comfort is important though - if your bike isn't comfortable you are less likely to want to ride it.
If you find lowering your handlebars to be uncomfortable, give it 4-5 rides to see if your body adapts. You may be forced to choose between comfort and performance (or work on your core strength and mobility).
Lower bars will always help in climbing too, as it is easier to keep enough weight over the front wheel.
With today's taller bikes most of us could benefit from lowering our bars. All of us could benefit from experimenting with bar height!
Go out and experiment. Take your time; change feels weird so weird isn't necessarily bad.
Hope this has been helpful!
