... would it be a good shifter cable replacement??
Let's discuss!!!
Let's discuss!!!
its gotta be a big-ass guitarWarp2003 said:... would it be a good shifter cable replacement??
Let's discuss!!!
have a standard 25-ish scale... basses are 34" or thereabouts. Why spend fat cash on a guitar string when cables are like $3.Warp2003 said:... would it be a good shifter cable replacement??
Let's discuss!!!
i like the xtr cables a lot. in hawaii we actually run a little bit different setup. instead of have a rear derailleur setup with 3 seperate housing pieces, we do the usual front piece and just have one long one from the top of the seat stay and all the way to the rear derailluer and just zip tie it to the seat stay. with the xtr cable it seems to shift awesome, especially since out conditions suck out here. try the xtr's they are pretty sweet.Warp2003 said:... would it be a good shifter cable replacement??
Let's discuss!!!
a shifter cable is equivalent to about a 50g string which are wound around about a 17g center. I doubt it would be reliable and I suppose that it might stretch too much under shifting tensions.Warp2003 said:You guys are right...
I don't know what in the hell I was thinking of when I posted this stoopid question....
Zanetti makes a good point and maybe that's what I should've asked.
Why bike cables aren't flatwounds or have a construction (not equal) but similar to guitar strings? Flatwounds have very small friction. I dare to say much less than normal cables.
Now if we would find a practical use for vacuum tubes on bikes
Cheers all you bike/guitar junkies out there!
WTF is a pinch, and how do you play one?sime said:well i know it doesn't work the other way, i have tried to use a cable as a string in a pinch..................sustain was slightly lacking.
He meant he was in a hurry and no guitar strings were available.Dad Man Walking said:WTF is a pinch, and how do you play one?
Because on a guitar string the center strand takes all the tension, the stuff wound around it provides no structural strength, only width. This is why a wound g string sucks if you do bends a lot, it can't stand the stretching. In a shifter cable, all the strands carry the force. You don't really need a shift or brake cable flatwound because the strands are oriented in the direction of the movement, so there is very little friction there compared with a wound guitar string.Warp2003 said:Why bike cables aren't flatwounds or have a construction (not equal) but similar to guitar strings? Flatwounds have very small friction. I dare to say much less than normal cables.
