Hey guys, this isnt a frame building question, but a modifying question (this seemed the most appropriate forum). For tire clearance and smaller-than-stock chainring reasons, my top mount bottom swing front derailleur wound up having to be mounted with the derailleur clamp directly on top of a bottle cage boss. the slight bump out of the boss causes the derailleur clamp to not fully contact the tube throughout its circumference, and there are slight gaps between the tube and clamp (on each side of the boss). I was still able to clamp it on snugly, but im concerned the extra stress on the clamp. I was thinking i could grind the boss flush with the frame, but not sure if the threaded portion will then fall into the frame (im thinking its a rivet type of thread insert). What should i do? Leave it the way it is, or grind off the boss (will it weaken the frame?)? I have ridden it once this way, and the derailleur did not move, and is still mounted tightly.
